| Author |
Message |
37chief Long Time User
Posted: Sat Jan 05, 2013 12:06 pm Post subject: Tire pressure |
I checked the pressure in a tire this morning Temp was probably around 32. Pressure was down from predvious day by 8-10 lbs. About mid day it was back up the same amount. So if I want 80 lbs in my tires, is the pressure going to increase a lot when the tires hit the road. Should I just put in 80 lbs in at mid day and not worry about it? Stan |
| Back to top |
oleblu Long Time User
Posted: Sat Jan 05, 2013 12:54 pm Post subject: Re: Tire pressure |
Stan
Set your tire pressure at 80 with the tires "cold", meaning not driven more than a mile or so. The pressure will increase slightly when driven, maybe 4-5 pounds. That"s the way it should be done.
When the outside air temp goes back up (lets say to 60 or 70 degrees) then you need to check your pressure and adjust acordingly. Air pressure should be checked monthly. |
| Back to top |
504 Tractor Expert
Posted: Sat Jan 05, 2013 12:55 pm Post subject: Re: Tire pressure |
Check tire PSI cold. If you are going on a trip fill cold and if you check them hot you are just making sure they are the same, if three are 90psi and another is 75 psi you know the low tire needs attention. |
| Back to top |
flying belgian Tractor Expert
Posted: Sat Jan 05, 2013 1:04 pm Post subject: Re: Tire pressure |
Stan. Are you saying the pressure changed by 8-10lbs. with out even driving it? Went down first and then back up? Only thing changed was the time of day? You gotta get a new tire gauge. That's where your problem is. |
| Back to top |
Posted: Sat Jan 05, 2013 1:14 pm Post subject: Re: Tire pressure |
The tire guage is top of the line, no china crap. Tire was very cold in the morning, and hot in the afternoon. I will check again in the morning, as I know the exact pressure now. Stan |
| Back to top |
Hay_Man Regular
Posted: Sat Jan 05, 2013 1:30 pm Post subject: Re: Tire pressure |
Also will change like that as Low Pressure weather areas pass your area and high pressure builds back in. What you see on your tire gauge is a pressure differential between the air in your tire and the outside air pressure. |
| Back to top |
Hay_Man Regular
Posted: Sat Jan 05, 2013 1:34 pm Post subject: Re: Tire pressure |
Also as the air in the tire heats up, the pressure will go up. You have to anticipate the heat build-up as you drive down the road. That's why the tire's rated pressure is "cold". If you have too much pressure it the tire when cold, it will probably build up too much pressure as it heats up while going down the road and blow out. |
| Back to top |
John B. Tractor Expert
Posted: Sat Jan 05, 2013 1:38 pm Post subject: Re: Tire pressure |
Be sure to check the air pressure in your spare tire too Stan! The spare is out of sight out of mind usually. |
| Back to top |
Wayne in MN Long Time User
Posted: Sat Jan 05, 2013 1:40 pm Post subject: Re: Tire pressure |
10 degree temp change will cause about a 1 PSI change in tire pressure.
That is why us "northerners" put winter air (denser) in our tires each fall & summer air (not as dense) in come springtime. :>) |
| Back to top |
jon f mn Tractor Expert
Posted: Sat Jan 05, 2013 1:47 pm Post subject: Re: Tire pressure |
Air pressure on my truck tires only varies 1 or 2 pounds usually. They always drop slowly, but rarely gain more than a pound or two no matter how hot they get. I can count on about 5 lbs drop per month in my truck tires, a little more in the winter. I also would say try another pressure gauge. Heres a link to a test.
Untitled URL Link
| Back to top |
dpendzic Regular
Posted: Sat Jan 05, 2013 2:54 pm Post subject: Re: Tire pressure |
you could compute it using the universal gas law---PV=NRT if you know the volume of your tire. |
| Back to top |
showcrop Tractor Guru
Posted: Sat Jan 05, 2013 3:06 pm Post subject: Re: Tire pressure |
It is not all that unusual for an inexperienced tractor pulling competitor to get disqualified because of setting his hitch height early in the morning, and then those big tires sit in the hot sun for a couple hours and they grow. |
| Back to top |
Hay_Man Regular
Posted: Sat Jan 05, 2013 3:11 pm Post subject: Re: Tire pressure |
I run tires with heavy loads on them, so they get hot and the air inside them gets hot and expands, causing high pressures. I have noticed with the quality of tires going down these days, air will leak out easier. The air molecules are able to leak out past the tire plies with the heat and higher pressures. The heat deteriorates the tire material and the air is able to escape more and more. Nitrogen has larger molecules which stay in the tire better under pressure. But I don't use Nitrogen in my truck tires. I have noticed I have to add air more to the low-profile tires on the cars nowadays. They just don't hold enough volume of air to maintain pressure for very long. I guess that's why some shops put Nitrogen in those little tires. I think Green Slime helps seal the tires against heat deterioration and thus helps to maintain air pressure, but sure screws up those in-tire pressure sensors. |
| Back to top |
DiyDave Tractor Guru
Posted: Sat Jan 05, 2013 3:37 pm Post subject: Re: Tire pressure |
You need to change out all that summer air, and replace it with winter air, it's more dense, and less humid, so pressure stays more the same. If you live near a dairy, don't put in no dairy air... |
| Back to top |
Fred from MO Long Time User
Posted: Sat Jan 05, 2013 4:17 pm Post subject: Re: Tire pressure |
Now that was funny!! |
| Back to top |
