| Author |
Message |
Oaf Regular
Posted: Sat Jan 05, 2013 5:43 pm Post subject: Whats this on my converted alt? |
Hey All,
Anyone know what this doohickey is?
It"s on my 650 that had a 12V conversion forced upon it. The wire comes from the dash and goes into a splitter and is connected by this Radio Shack device. Any ideas if I actually need it?
I"ll see if the photo upload is friendly...
| Back to top |
Oaf Regular
Posted: Sat Jan 05, 2013 5:46 pm Post subject: Re: Whats this on my converted alt? |
It's the resistor/diode looking thing just above my proctologist glove. |
| Back to top |
souNdguy Tractor Guru
Posted: Sat Jan 05, 2013 5:58 pm Post subject: Re: Whats this on my converted alt? |
a resistor..
and?
it should be in between key switch and #1.
with #2 jumped to charge stud.
it's the isolation device that takes the place of a 194 lamp or diode to isolate the vreg in the alt from the ignition.
no high magic here..  |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12436 Location: Twin Cities
Posted: Sat Jan 05, 2013 6:10 pm Post subject: Re: Whats this on my converted alt? |
Forced upon it?
I'd say the tractor was lucky.
Or you are. |
| Back to top |
Posted: Sat Jan 05, 2013 6:21 pm Post subject: Re: Whats this on my converted alt? |
one thing i'll say. the alt conversions for the 53-64 machines are clean.. you can hang one on with a commercially available bracket set.. or easilly make your own, and it looks good.. not kludged or grafted. AND you don't sacrifice anything at all.. period... .. like with a 65+ tach drive unit genny.
I actually don't mind an alt on a 53-64... though I do like my stealth 12v conversion on my 950 using a gen from a diesel 01  |
| Back to top |
Oaf Regular
Posted: Sat Jan 05, 2013 6:38 pm Post subject: Re: Whats this on my converted alt? |
Might not be magic to you guys, but that's why I asked.
Is there an inline version of this resistor? This one is already corroded because the alternator and this piece jut outside the hood and was in the elements for years before I bought it. |
| Back to top |
Oaf Regular
Posted: Sat Jan 05, 2013 6:40 pm Post subject: Re: Whats this on my converted alt? |
You don't see all the taped up wire nuts that are scabbed onto the harness. I'd rather have stock 6V and do my own butchery. |
| Back to top |
Posted: Sat Jan 05, 2013 6:46 pm Post subject: Re: Whats this on my converted alt? |
you are looking at the 'inline' version.
inline is just a mounting technique.. :)
you can clean it up and just resolder it to wires and tuck unde the hood.. etc. |
| Back to top |
Posted: Sat Jan 05, 2013 6:47 pm Post subject: Re: Whats this on my converted alt? |
do it! |
| Back to top |
David G Tractor Guru
Posted: Sat Jan 05, 2013 6:55 pm Post subject: Re: Whats this on my converted alt? |
I put my diodes in with a crimp connector on each end and cover all of it with heat shrink. It looks pretty good. |
| Back to top |
Oaf Regular
Posted: Sat Jan 05, 2013 7:09 pm Post subject: Re: Whats this on my converted alt? |
To replace it, I just take it to Radio Shack and ask for a new one the same color code, or is there a certain type recommended? |
| Back to top |
Posted: Sat Jan 05, 2013 7:21 pm Post subject: Re: Whats this on my converted alt? |
why replace it.. just re-use it.
you are trying awfully hard to make this very easy issue very very difficult.
it's a resistor.. it don't go bad unless it smokes and burns in two or the legs break off.
clean up and put some crimp connectors on it and re-hook it.
or stick a 194 lamp inline from key to #1 |
| Back to top |
Oaf Regular
Posted: Sat Jan 05, 2013 8:32 pm Post subject: Re: Whats this on my converted alt? |
Sounds good. Thanks for the help one and all! |
| Back to top |
Posted: Sun Jan 06, 2013 3:15 am Post subject: Re: Whats this on my converted alt? |
Your tractor, your call of course.
How many other 6V machines do you have?
What's in your daily runner, wife's car, lawn tractor, motorcycle, 4 wheeler, snowmobile, boat, RV/camper or hot rod if you have them?
Why would anyone want an oddball 6V machine that can't jump or easily Be jumped by everything else he has? |
| Back to top |
Oaf Regular
Posted: Sun Jan 06, 2013 7:45 am Post subject: Re: Whats this on my converted alt? |
I ride British motorcycles. 6V pos ground neither thrills me nor scares me.  |
| Back to top |
