| Author |
Message |
WayneMo Regular
Posted: Sat Jan 05, 2013 8:45 pm Post subject: 641 6v solenoid wiring |
My 641 6v solenoid has 2 small terminals. I assume one connects to the switched side of the ignition switch and the other connects to ground through the starter button. Which one does the top terminal connect to and which does the bottom terminal connect to? Also the bottom terminal now has 2 wires connected to it instead of 1, what is the second wire connect to? |
| Back to top |
JMOR Tractor Guru
Posted: Sat Jan 05, 2013 9:17 pm Post subject: Re: 641 6v solenoid wiring |
| waynemo wrote: | | (quoted from post at 00:45:54 01/06/13) My 641 6v solenoid has 2 small terminals. I assume one connects to the switched side of the ignition switch and the other connects to ground through the starter button. Which one does the top terminal connect to and which does the bottom terminal connect to? Also the bottom terminal now has 2 wires connected to it instead of 1, what is the second wire connect to? | see other forum! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
