Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
John Deere 322 charging system
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
jd730gas
PostPosted: Sun Jan 06, 2013 8:03 am    Post subject: John Deere 322 charging system Reply to specific post Reply with quote
I have a JD 322 that I really enjoy. Right at the end of leaf collection season my battery charge light came on. Eventually of course when I shut it off to empty bags it would not start. After charging it up it will start and work of course but light is still on and now electric mower clutch will not engage. Where do I start? Alternator/generator; voltage regulator; mower electric clutch; battery or combination? Thank you for any help.
El Toro
PostPosted: Sun Jan 06, 2013 8:44 am    Post subject: Re: John Deere 322 charging system Reply to specific post Reply with quote
Which engine do you have? If it's a Kohler it may have a stator that produces Ac voltage and you would also have a rectifier/regulator to convert the AC to DC volts. You can use a volt meter set on AC volts and with the engine at 1/2 throttle or better you can measure the ac output voltage off the stator should be about 30 volts.
If that looks ok switch your meter to Dc volts and measure that. Be careful working around that engine. You can measure the DC volts across the battery terminals, should see around 14 volts. If you only have 12 volts your rectifier is probably defective.. Hal
jd730gas
PostPosted: Sun Jan 06, 2013 7:31 pm    Post subject: Re: John Deere 322 charging system Reply to specific post Reply with quote
Thank you. It is a 3 cylinder, either a Yanmar or Kawasaki I believe. I suppose it could be dusty and dirty connections because it was really dirty chopping and bagging leaves and worked fine for several hours.
El Toro
PostPosted: Mon Jan 07, 2013 5:25 am    Post subject: Re: John Deere 322 charging system Reply to specific post Reply with quote
You should check with your local JD dealer to see if they will scan a copy of the wiring diagram on your charging system. If it has an alternator you should have a rectifier. It may just be a loose wire or a bad connection. I had a JD 140 that wouldn't charge and it just needed the terminals cleaned on the rectifier. Hal
El Toro
PostPosted: Mon Jan 07, 2013 5:40 am    Post subject: Re: John Deere 322 charging system Reply to specific post Reply with quote
Here's a link for troubleshooting your charging circuit. Hal
Untitled URL Link
Ken Combs
PostPosted: Mon Jan 07, 2013 10:17 am    Post subject: Re: John Deere 322 charging system Reply to specific post Reply with quote
That uses a small belt driven alternator. Most likely it is the regulator as the alt seldom fail.
That is a 3cyl yanmar gas right??
Bob
PostPosted: Wed Jan 09, 2013 7:29 am    Post subject: Re: John Deere 322 charging system Reply to specific post Reply with quote
IMHO, most common failure with that system is the multiple contact electrical plug between the alternator and rectifier/regulator.
stronics
PostPosted: Wed Jan 09, 2013 2:31 pm    Post subject: Re: John Deere 322 charging system Reply to specific post Reply with quote
Gentlemen,
There are ways to check out the system, get the correct diagram and check it.
Does the alternator have 27-35 AC volts? Is it getting to the regulator? Are you getting around 13 or higher volts DC at the battery.
David
