| Author |
Message |
haythrower New User
Joined: 03 Jan 2013 Posts: 5 Location: West central Alabama
Posted: Sun Jan 06, 2013 8:25 am Post subject: Case 2390 clutch/shifting problems |
My 2390 dies instantly when i fully depress the clutch and it builds up pressure so that it won't allow the motor to spin over freely. After about 5-10 mins, it spins over freely and cranks easily.Also when i do get it going if i put the powershift into 3rd, no mater what gear i have the 4 speed in, it chokes the motor down. I can pull it back into 2nd and it takes right back off. Does anybody have any suggestions? Thanks. |
| Back to top |
Case Nutty 1660 Tractor Guru
Posted: Sun Jan 06, 2013 8:28 am Post subject: Re: Case 2390 clutch/shifting problems |
pilot spool stuck, quit running it or you will pay dearly for repairs,,, some one will walk you through how to fix spool cnt |
| Back to top |
haythrower New User
Posted: Sun Jan 06, 2013 8:40 am Post subject: Re: Case 2390 clutch/shifting problems |
Thanks for the info. I'm not runnung it at all. Just moved it enough to get it out if the field. |
| Back to top |
2290 Regular
Posted: Sun Jan 06, 2013 12:41 pm Post subject: Re: Case 2390 clutch/shifting problems |
Hi,
It sounds like c-1 pilot spool is stuck.Remove the plug on c-1 and use a 10/24 screw and thread it in the spool then pull it out.Wash it out with brake clean or something equal. Clean spool,oil it and reinstall it make sure it moves smoothly.
2290 |
| Back to top |
mEl Tractor Guru
Posted: Sun Jan 06, 2013 12:48 pm Post subject: Re: Case 2390 clutch/shifting problems |
What 2290 said.. When you get it freed up, change the tranny filters and if it's been a while, the oil also. Your system is probably geting contaminants past the filter bypasses and allowing crud to go straight to the powershift valve which has aluminum lands which allow metal particles to imbed easily.
If you change the oil, HYtran Ultra is the only acceptable oil IMHO.
mEl |
| Back to top |
coreyc Regular
Posted: Sun Jan 06, 2013 4:49 pm Post subject: Re: Case 2390 clutch/shifting problems |
As MEL stated use hytran oil only or you will be replacing brake plates, pto plates, rps(power shift) transmission plates in the future due to them separating.. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
