| Author |
Message |
Jziemer Regular
Posted: Sun Jan 06, 2013 11:50 am Post subject: Is there some truth to this? |
The other day I was talking to a guy and he claims that if your
international tractor has bigger duals than the inside tire it will
turn on the headlands a lot easier and you will be able to pull
bigger equipment. Is there any truth to this? |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18461 Location: St. Cloud, MN
Posted: Sun Jan 06, 2013 12:17 pm Post subject: Re: Is there some truth to this? |
No it is a great way to break axles.
On hard ground, the farther the contact wheels are from the steering tires, the wider the turn.
In soft ground, the wider the deepest penetration the more they try to turn the tractor despite where the front wheels are pointing. Jim |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6543 Location: Delta,colorado
Posted: Sun Jan 06, 2013 12:27 pm Post subject: Re: Is there some truth to this? |
May turning easier 'empty',but would make no difference pulling a load.As Jim says"good way to break axles".If you have differing size tires,run the bigger inside,the smaller out. |
| Back to top |
pete 23 Tractor Expert
Posted: Sun Jan 06, 2013 1:04 pm Post subject: Re: Is there some truth to this? |
Keep in mind that your inside tire is still supposed to be the main driving force. Never want the outer tire larger than inner. If tires are same size it is a good idea to run a few pounds less air in outside tire. I have seen way too many dual hubs give problems due to slightly over sized outer tire or over inflated or just a identical tire with more tread making it over sized. |
| Back to top |
Jziemer Regular
Posted: Sun Jan 06, 2013 2:07 pm Post subject: Re: Is there some truth to this? |
Ok and I'm not 100% sure if he was talking about band duals or hub duals but I'm assuming that the same would be true for band duals? |
| Back to top |
MisterT Long Time User
Posted: Sun Jan 06, 2013 2:16 pm Post subject: Re: Is there some truth to this? |
| Jziemer wrote: | | (quoted from post at 23:07:07 01/06/13) Ok and I'm not 100% sure if he was talking about band duals or hub duals but I'm assuming that the same would be true for band duals? |
The same rules apply, whether axle mount or band style. |
| Back to top |
Too Far Gone Long Time User
Posted: Sun Jan 06, 2013 3:14 pm Post subject: Re: Is there some truth to this? |
Dont visit with folks near the nuthouse fences anymore |
| Back to top |
Jason the Red Long Time User
Joined: 12 May 2009 Posts: 719 Location: Grain Valley MO
Posted: Sun Jan 06, 2013 4:38 pm Post subject: Re: Is there some truth to this? |
Maybe some truth to it if your right side tires were larger than your left side tires and you were making left hand turns. That technically would make your right side tires the "outer tires" in the turning radius, however its feasability is non-existant. |
| Back to top |
Jziemer Regular
Posted: Sun Jan 06, 2013 5:58 pm Post subject: Re: Is there some truth to this? |
Ok that's what I was kinda thinking to. I was wanting to buy duals for my 986 which has 18.4 38s and the duals he was trying to sell we're 20.4-38s and I figured I better get some more opinions on this |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5458 Location: SE Wisconsin
Posted: Sun Jan 06, 2013 6:13 pm Post subject: Re: Is there some truth to this? |
| pete 23 wrote: | | (quoted from post at 14:04:27 01/06/13) Keep in mind that your inside tire is still supposed to be the main driving force. Never want the outer tire larger than inner. If tires are same size it is a good idea to run a few pounds less air in outside tire. I have seen way too many dual hubs give problems due to slightly over sized outer tire or over inflated or just a identical tire with more tread making it over sized. |
The Deere manuals all call for that right in the book. Can't speak for a CIH manual because I have never read one. |
| Back to top |
Jziemer Regular
Posted: Sun Jan 06, 2013 6:40 pm Post subject: Re: Is there some truth to this? |
I guess the only reason I thought it would possibly work was I have seen tractors wit 20.8-38 tires inside and 18.4-38 tires as duals so I was thinking mane it would work with the 18.4-38 tires inside and the 20.8-38 as the duals. Thanks for the help |
| Back to top |
Posted: Sun Jan 06, 2013 7:40 pm Post subject: Re: Is there some truth to this? |
If the deal is incredible, why not swap the inner for the outer and be done with the issue? |
| Back to top |
John B. Tractor Expert
Posted: Sun Jan 06, 2013 7:53 pm Post subject: Re: Is there some truth to this? |
If you have larger tires on one side than the other this will make your spider gears in you differential constantly walk even when driving in a straight line, because the smaller tires will be making more revolutions! |
| Back to top |
GeneMO Tractor Expert
Posted: Sun Jan 06, 2013 8:40 pm Post subject: Re: Is there some truth to this? |
If you dont mind replacing broken axle bolts every other day. I am talking about the old type that clamp on the rim. You get too much pressure from that outer dual and you will break the bolt that hold the wheels to the axle. Least we did on our 706 and 766.
Gene |
| Back to top |
ihman73 Regular
Posted: Sun Jan 06, 2013 10:18 pm Post subject: Re: Is there some truth to this? |
As long as the diameter is the same it doesn't matter where the wider tire is. But put a larger diameter tire outside of a smaller diameter hard parts will break. |
| Back to top |
