| Author |
Message |
BobMFD New User
Posted: Sun Jan 06, 2013 11:57 am Post subject: Farmall H Carb |
My 1948 H had not been run for about a month and when I started it up the other day it would not run evenly it surges up snd down. I rebuilt the carb and cleaned it, that did not help a lot, If I hold the choke half closed it runs great. any suggestions? |
| Back to top |
The Red Tractor Guru
Posted: Sun Jan 06, 2013 12:04 pm Post subject: Re: Farmall H Carb |
Open the high speed mixture screw by a half turn and see if that helps. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50670 Location: Lake of the Ozarks area of MO
Posted: Sun Jan 06, 2013 12:16 pm Post subject: Re: Farmall H Carb |
Sounds like when you rebuilt the carb you missed some dirt/rust when you did so. You need to use a wire or as I use a torch tip cleaner tool to poke out all the passage ways to make sure they are clear. You also as per the manual have o then set the governor to the carb due to having it off the tractor as per what the I-T manual says |
| Back to top |
rustred Tractor Expert
Posted: Sun Jan 06, 2013 1:09 pm Post subject: Re: Farmall H Carb |
did you disassemble it and soak it? is the float level set?
how have you adjusted it?
what are the main and mixture screws set at?
it may be as easy as opening the main needle valve. hard to say unless you say what you have done. |
| Back to top |
MisterT Long Time User
Posted: Sun Jan 06, 2013 2:14 pm Post subject: Re: Farmall H Carb |
| BobMFD wrote: | | (quoted from post at 20:57:25 01/06/13) My 1948 H had not been run for about a month and when I started it up the other day it would not run evenly it surges up snd down. I rebuilt the carb and cleaned it, that did not help a lot, If I hold the choke half closed it runs great. any suggestions? |
If it runs okay with the choke 1/2 out, it is starving for fuel. Did you clean the screen behind the fuel inlet fitting? Is the sediment bowl under the tank clean? Is the shut-off on the sediment bowl open all the way?
It is also quite possible that the needle valve is partially stuck in the seat, even if you installed a brand new needle and seat. Smacking the carburetor with the handle of a large screwdriver will usually convince the needle valve to do its job properly. |
| Back to top |
FBH44 Long Time User
Posted: Mon Jan 07, 2013 3:51 am Post subject: Re: Farmall H Carb |
Same thing on my H, and I had checked everything. Took the sediment bowl out, and I thought it was clean and clear, but inside the bowl inlet I had two little passages that had sediment, blocking flow. Removed the sediment, and all fixed. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
