| Author |
Message |
tntleake Regular
Posted: Sun Jan 06, 2013 1:43 pm Post subject: Latest purchase Farmall 200 |
I bought this tractor knowing it has water in the oil. I'm hoping a head gasket. Has old repair to black behind carb. Valves have been added, but original fast hitch valve is still inplace. Looks like they plumbed around the original H?H valve and set up new valve to run fast hitch and additional valve for a remote. All 4 tires are new Firestones, rear hubs I think are from an H, tires are 13.6x38. I'm moving them over to a 460 I have hubs/rims tires from an donor SC to put on it. Also can use the block from the SC if I have a bad block on the 200
How'd I do
Any suggestion on the water in oil. Will start pulling engine apart tonight
As always thanks for your comments and advice.
Tracy
| Back to top |
tim11612 Guest
Posted: Sun Jan 06, 2013 1:50 pm Post subject: Re: Latest purchase Farmall 200 |
love it,great shape. |
| Back to top |
The Red Tractor Guru
Posted: Sun Jan 06, 2013 1:57 pm Post subject: Re: Latest purchase Farmall 200 |
Not a whole lot of 200s around. Your's looks very nice. Those are M rims and tires!! |
| Back to top |
tntleake Regular
Posted: Sun Jan 06, 2013 2:01 pm Post subject: Re: Latest purchase Farmall 200 |
I paid 1K for it all |
| Back to top |
tntleake Regular
Posted: Sun Jan 06, 2013 2:03 pm Post subject: Re: Latest purchase Farmall 200 |
I think H because of axle and Hub diameter, but I could be wrong. M axles are alot bigger |
| Back to top |
Posted: Sun Jan 06, 2013 2:07 pm Post subject: Re: Latest purchase Farmall 200 |
I would agree those are H hubs but the rims are probably M width. 13.6 x 38 are the tire size on my two Ms. H and M hubs had the same outside diameter for the rims of either an H or M. |
| Back to top |
Posted: Sun Jan 06, 2013 2:08 pm Post subject: Re: Latest purchase Farmall 200 |
Heck of a price. I hope the water in the oil is not an expensive fix. |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Sun Jan 06, 2013 2:27 pm Post subject: Re: Latest purchase Farmall 200 |
It looks like a great deal especially with the tires.
Zach |
| Back to top |
Iamarv Regular
Posted: Sun Jan 06, 2013 2:28 pm Post subject: Re: Latest purchase Farmall 200 |
Most likely the O ring around the sleeve is leaking and allowing antifreeze to get in the oil. Could be a leaking headgasket also. The real problem could be the damage caused by the antifreeze in the oil. It is VERY damaging to the lower engine parts. (crank, rod, and main bearings etc) Keep us posted. |
| Back to top |
kopeck Long Time User
Posted: Sun Jan 06, 2013 2:32 pm Post subject: Re: Latest purchase Farmall 200 |
| tntleake wrote: | (quoted from post at 14:43:16 01/06/13) I bought this tractor knowing it has water in the oil. I'm hoping a head gasket. Has old repair to black behind carb. Valves have been added, but original fast hitch valve is still inplace. Looks like they plumbed around the original H?H valve and set up new valve to run fast hitch and additional valve for a remote. All 4 tires are new Firestones, rear hubs I think are from an H, tires are 13.6x38. I'm moving them over to a 460 I have hubs/rims tires from an donor SC to put on it. Also can use the block from the SC if I have a bad block on the 200
How'd I do
Those wheel/tires would look right at home on my SM, on a 200 they look HUGE!
For 1k you did pretty good if the rubber really is new.
Have fun, our 200 was the main tractor on the farm for many, many years.
K |
| Back to top |
D Slater Tractor Expert
Posted: Sun Jan 06, 2013 2:37 pm Post subject: Re: Latest purchase Farmall 200 |
Looks like 2 different rear rim types and maybe wideth.
But heck thats a good deal for the tires and front wheel weights. Not counting the tractor don't look bad. |
| Back to top |
ken house Regular
Posted: Sun Jan 06, 2013 4:41 pm Post subject: Re: Latest purchase Farmall 200 |
your post says water in the oil. if you have anti-freeze in the radiator. you probably do not have a problem. water will accumulate in the cases. i would crack open the crankcase and drain the water, (if it is water) and let the water out and run for a bit, let it sit and check again. |
| Back to top |
Iamarv Regular
Posted: Sun Jan 06, 2013 5:48 pm Post subject: Re: Latest purchase Farmall 200 |
I posted earlier assuming water meant antifreeze. Sorry to alarm you. You must be in a warm climate judging by the green leaves on the trees. In Iowa all radiators has antifreeze in them. |
| Back to top |
Glenn F. Guest
Posted: Sun Jan 06, 2013 7:49 pm Post subject: Re: Latest purchase Farmall 200 |
While I expect they'd cause problems, personally I like those big tires on there.
Glenn F. |
| Back to top |
Dean Olson Long Time User
Posted: Mon Jan 07, 2013 8:09 am Post subject: Re: Latest purchase Farmall 200 |
How does that wheel mounting work?
I thought 200 and H axles are different sizes.
I went from 11.2X36" to 12.4X36" on my SC and noticed a decrease in power. I'll bet that set up really sucks HP. |
| Back to top |
