Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
fly wheel timing port?
Post new topic    Yesterday's Tractors Forum Index -> Allis Chalmers
RalphWD45
PostPosted: Sun Jan 06, 2013 1:43 pm    Post subject: fly wheel timing port? Reply to specific post Reply with quote
I removed the engine from my wd45, to replace the clutch and pressure plate. was ready to lower it back in, and buckle it up, when I decided to find the flywheel timimg marks, and paint them white with a paint pencil, so I can see them easier. I found two places with a mark with an F on them, and they are directly oppisite each other. 180 deg. I brought the number one piston up on compression stroke, to the top, by feel, and looked at my marks, to locate where in the bell housing, that the timing hole should be. No holes anywhere in my bell housing when viewed from outside, or inside. IT manual says view timing mark thru hole on lower bell housing.(BS) I looked at 3 small Allis's and the B, C, &CA, all had the hole in the bell on the left side . I gave up and am here on the forum asking for help, also I removed the govener with distributer attatched, so I will have to retime it. If the hole is in the inspection plate, on the bottom of the bell housing, how do you use it with the timing mark 30 deg higher up on the flywheel?
steve(ill)
PostPosted: Sun Jan 06, 2013 2:27 pm    Post subject: Re: fly wheel timing port? Reply to specific post Reply with quote
not sure, but i thought the inspection hole was on the bottom. Normally you "time" the motor at TDC as they startup / fire at that point. After the motor is running, the spark will advance to 30 degrees with the magnito or distributor weights. You can see it fire at "F" later with a timing light.
Bob Bancroft
PostPosted: Sun Jan 06, 2013 2:33 pm    Post subject: Re: fly wheel timing port? Reply to specific post Reply with quote
As I recall, they were timed through the bottom hole. Seems like there's a little chisel mark down there somewhere. There should be TDC and a firing mark.
Dick L
PostPosted: Sun Jan 06, 2013 3:18 pm    Post subject: Re: fly wheel timing port? Reply to specific post Reply with quote
Any engine starts out being timed to TDC on number one cylinder on the compression stroke without the engine running. When running you will find the F (fire) line with a timing light. All engines are not timed at 30 degrees advanced but yours is. There is a procedure where you time the engine using the fire line when using a magneto to set the magneto without loading the spring.
Some get confused between the two. They both come out the same if you understand which one you are using and what you are needing at the end.
Starting with the TDC means you will have to check your spark on the compression stroke after assembly to make sure you are not 180 degrees off. In doing so you will know you are on target.
anallisguy
PostPosted: Sun Jan 06, 2013 4:10 pm    Post subject: Re: fly wheel timing port? Reply to specific post Reply with quote
a couple of inches away from the fire marks you will find a tdc line, probably not marked. will be on the bottom when on tdc, and possibly not visible thru the opening in the bottom of the bell housing. the set screw that holds the crank pulley will be at the bottom of the crank rotation at 6 oclock when you are on tdc.
funky_g00
PostPosted: Sun Jan 06, 2013 8:37 pm    Post subject: Re: fly wheel timing port? Reply to specific post Reply with quote
Turn the engine until see the TDC line NOT the Fire line in the inspection hole on bottom of bell housing. There should be a line or notch front and center of inspection hole. Install magneto set to #1 cylinder. (remember to rotate the mag backwards to set it to #1 or else your timing will be off). Start tractor, once started, check with timing light, the Fire line should now be visible thru inspection hole. Adjust accordingly. This is the procedure for framed allis"s (WC,WD,WD45). All others are considered frameless and use the side inspection hole but basically timed the same.
RalphWD45
PostPosted: Sun Jan 06, 2013 10:36 pm    Post subject: Re: fly wheel timing port? Reply to specific post Reply with quote
I got the engine back in by dark tonight, and buckled up to the mounts, If the temp holds till tomarrow, I plan to install the govener and dist, then We will see if I understand correctly, what you guys have told me
