| Author |
Message |
bc5210 Guest
Posted: Sun Jan 06, 2013 4:05 pm Post subject: 2130 intermittent hyd |
Ok so I tried a few things with my tractor to try figure out my prob. Changed stroke control valve and seat, set pump press at 2250 I have 7gal/min flow. Works fine for about an hr and then bam! no hyd! or steering. Shut engine off restart get hyd again. Checked rockshaft housing for spraying oil, nothing in there. Not sure where to look from here. |
| Back to top |
tim s Tractor Guru
Joined: 01 Nov 2008 Posts: 5936 Location: Somerset Ohio
Posted: Sun Jan 06, 2013 4:17 pm Post subject: Re: 2130 intermittent hyd |
Drain the trans oil and pull the sump screen, it's located behind the filter running cross ways in the bottom of the case, a plug with a place for a 1/2" square drive in it...see what you find,,if you find what looks like an old wool coat chewed up it's brake lining, carefully clean the dirt out and be careful not to "scoop" up anything when you re-install the screen.. |
| Back to top |
bc5210 Guest
Posted: Sun Jan 06, 2013 5:02 pm Post subject: Re: 2130 intermittent hyd |
When my prob first started I changed oil and filter and pulled pickup screen all looked good. |
| Back to top |
tim s Tractor Guru
Posted: Sun Jan 06, 2013 5:05 pm Post subject: Re: 2130 intermittent hyd |
Good,, that's the place to start,,how long will the hydraulics work after you re-start?? |
| Back to top |
tim s Tractor Guru
Posted: Sun Jan 06, 2013 5:12 pm Post subject: Re: 2130 intermittent hyd |
Okay i just re-read your post about an hour,,there is a strong chance that you have a cracked pressure tube in the trans. pump area, when they get a crack in them they will open up a bit when the oil warms up dumping the trans. pump oil back into the case letting the main pump starve for oil, when you shut it of for a bit it will settle down and not leak as bad till it heats up again, I have seen this several times,,a weak trans pump can add to the problem,,I'm thinking your gonna be splitting it at the transmission/ clutch housing ,,,but before you do try to see if the problem changes any with the PTO on or in hi,,or low range |
| Back to top |
bc52109 Guest
Posted: Sun Jan 06, 2013 5:43 pm Post subject: Re: 2130 intermittent hyd |
prob a min or two then quit again |
| Back to top |
bc5210 Guest
Posted: Sun Jan 06, 2013 6:04 pm Post subject: Re: 2130 intermittent hyd |
ok I will try it with the pto running, are you thinking it will make it worse? I don't have high and low |
| Back to top |
tim s Tractor Guru
Posted: Sun Jan 06, 2013 6:11 pm Post subject: Re: 2130 intermittent hyd |
It may change the way it happens with the PTO working, just a way of isolating things before you split..and I'm afraid that will be next Darn it.. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13091 Location: Coyote Flats,Tx
Posted: Mon Jan 07, 2013 4:30 am Post subject: Re: 2130 intermittent hyd |
Another place to check would the hyd filter relief valve to be sure it seating.
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
