| Author |
Message |
dmiller Long Time User
Posted: Sun Jan 06, 2013 4:47 pm Post subject: Hydraulic lift control forks and control valve |
So I now have the forks where they go (I think) on my 9n and the lift cover goes all the way down so I can bolt it in place.
What exactly do the ends of the fork attach to? It feels like there is a little T shaped piece (maybe 1/4 inch or smaller rod??) that's fairly loose down there. Do the ends of the fork go over either side of that T??? What exaclty does the end of the valve feel like?? |
| Back to top |
JMOR Tractor Guru
Posted: Sun Jan 06, 2013 4:59 pm Post subject: Re: Hydraulic lift control forks and control valve |
| dmiller wrote: | (quoted from post at 20:47:59 01/06/13) So I now have the forks where they go (I think) on my 9n and the lift cover goes all the way down so I can bolt it in place.
What exactly do the ends of the fork attach to? It feels like there is a little T shaped piece (maybe 1/4 inch or smaller rod??) that's fairly loose down there. Do the ends of the fork go over either side of that T??? What exaclty does the end of the valve feel like?? | You seem to show that you have no manual, know so little about it, makes me ask, how did you take it apart without breaking something?
| Back to top |
ZANE Tractor Guru
Posted: Sun Jan 06, 2013 5:59 pm Post subject: Re: Hydraulic lift control forks and control valve |
Perfect! A picture is worth a thousand words.
(old chinese proverb)
Zane |
| Back to top |
Posted: Sun Jan 06, 2013 7:16 pm Post subject: Re: Hydraulic lift control forks and control valve |
Hope I haven't broken something. This is the first Ford I've been around. (other than a 600 I'm also working on.) |
| Back to top |
| Back to top |
Posted: Mon Jan 07, 2013 7:04 pm Post subject: Re: Hydraulic lift control forks and control valve |
Got a chance to work on it again this evening. Found out I did break the end off of the control valve.
So... how does the control valve come out so I can replace it now too????? |
| Back to top |
Charnerl Regular
Posted: Mon Jan 07, 2013 7:57 pm Post subject: Re: Hydraulic lift control forks and control valve |
You may or may not need to replace the "T" valve. It slids out the back and the new one slids right in. The two prongs are sprad apart and slip onto the end of the "T" valve. I did notice the two prongs going down to the "T" valve seem to be spread apart. If so it will probably slip off the "T" valve. I had to put two large radiator hose clamps around the prongs to pull them in close together so as come loose. You need a manual. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
