| Author |
Message |
Matt Reinders Regular
Posted: Sun Jan 06, 2013 7:49 pm Post subject: 1953 Wd45 electrical |
I am in the final stages of my very first restoration of this wd45. I bought it with a toggle switch to start the engine, but I am putting a key switch back on it. The switch has two ends on it and one end gets wired to the coil. The other end I am not sure if it gets wired to ground or to the ammeter. If it is the ammeter, does it get wired to the positive or negative? Hopefully I have provided enough info to get the question answered. Thanks in advance. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50659 Location: Lake of the Ozarks area of MO
Posted: Sun Jan 06, 2013 7:59 pm Post subject: Re: 1953 Wd45 electrical |
Restoration??? So did you bring it back to what it was new from top to bottom??? If you say not then it is not restored or even close. I hate that term since few can read what Webster says it means.
That said it should have a distributor so it has to get battery power to the coil so it will run. As for which side of the amp gauge you hook it to the side that goes the the battery. The other side of that gauge should go to the charging system |
| Back to top |
Posted: Sun Jan 06, 2013 8:31 pm Post subject: Re: 1953 Wd45 electrical |
Thanks for the help old. I apologize if I have offended you with the term restoration. I would agree that the term can be used loosely and is based on ones interpretation of the word. For your peace of mind here is what has been done to the tractor. The block was decked and hot tanked, new sleeves, new pistons, new rings, new main and journal bearings, all new gasket kit, new electrical harness, new ammeter, new radiator, new temperature gauge, new tires, new front tire seals, one new rear rim, the other was repaired, all sheet metal was sandblasted, primed then painted, new battery box, original rear light was added back, brand new decal kit, new hydraulic hoses. I think that is it. That is my interpretation of a restoration, I hope it fits your definition. Thanks again for your help and I'll be sure to pot picks when I am done. |
| Back to top |
cleddy Regular
Posted: Mon Jan 07, 2013 7:10 am Post subject: Re: 1953 Wd45 electrical |
You may already have this info out of a original WD-45 Oper. Manual and AC Service Manual and it is a little confusing since the manuals give information for the magneto and the old style generator cut-outs.
My tractor has been updated to a 12 volt generator with a new style Gen/Regulator and I use the key switch and original light switch for lights only(not charge rate).I would like to see pictures of your tractor since it sound like a good restoration job.Hope this helps.cleddy
| Back to top |
cleddy Regular
Posted: Mon Jan 07, 2013 7:47 am Post subject: Re: 1953 Wd45 electrical |
That did not work very good. I'll try one page at a time.cleddy
| Back to top |
Posted: Mon Jan 07, 2013 8:01 am Post subject: Re: 1953 Wd45 electrical |
Thanks Cleddy. I did have those forms, but yes I was confused based on the old diagrams. The handwritten notes will help. I think I have everything straightened out now. I will post pics by next week. |
| Back to top |
old Tractor Guru
Posted: Mon Jan 07, 2013 8:19 am Post subject: Re: 1953 Wd45 electrical |
Your close to the term restore now all you have to do is rebuild the transmission and rear end to be a full restore LOL.
As for help I hope what I said helped you |
| Back to top |
Ted in NE-OH Regular
Joined: 28 Nov 2012 Posts: 298 Location: Austinburg Ohio
Posted: Mon Jan 07, 2013 9:17 am Post subject: Re: 1953 Wd45 electrical |
I believe that the ignition switch (distributor) should be wired to the LOAD side if the amp meter not the battery side. That way the current for the ignition registers on the amp meter. Am I wrong? |
| Back to top |
BushogPapa Tractor Guru
Posted: Mon Jan 07, 2013 10:25 am Post subject: Re: 1953 Wd45 electrical |
Guess me need to advise all NEW-comers that the Politically CORRECT term has become "Resurrected"..
Restored ONLY applies to "EXPO-Quality" Restorations now...
Come on, fellas...these are TRACTORS, for Heaven's sake..I don't like to see those "SNERT" type remarks here...WE are supposed to be "Better" than our City brethren...
Ron.. |
| Back to top |
Brampton 02 GT New User
Posted: Tue Jan 08, 2013 6:46 pm Post subject: Re: 1953 Wd45 electrical |
What if they don't need to be repaired? If you inspect the rear end and tranny does that count? |
| Back to top |
Justin SE IOWA Long Time User
Joined: 21 Sep 2010 Posts: 574 Location: Oskaloosa Iowa
Posted: Tue Jan 08, 2013 7:13 pm Post subject: Re: 1953 Wd45 electrical |
Geeze "old" take a deep breath and calm down. He isnt trying to sell it to you so you have no need to jump down his throat. I think an apology is in order. just sayin... |
| Back to top |
old Tractor Guru
Posted: Tue Jan 08, 2013 7:40 pm Post subject: Re: 1953 Wd45 electrical |
If things measure out to be in spec yes then it is covered. Reason I am so tight on this is I have seen far to many that said it was original and have aftermarket aluminum valve covers or a tractor like say a WD with WD45 decals but yet the guy would swear up down and side ways it was in fact a WD45 but yet the engine had the WD side cover and the shifter was the WD straight shifter so over the years I have found the term restore was fiction in at least 75% of the stuff and yes I will call them out |
| Back to top |
stu (ON) Regular
Posted: Tue Jan 08, 2013 7:54 pm Post subject: Re: 1953 Wd45 electrical |
old, are you sayin' that you are from Missouri? |
| Back to top |
old Tractor Guru
Posted: Tue Jan 08, 2013 8:06 pm Post subject: Re: 1953 Wd45 electrical |
No I live in Missouri but was born in Alabama LOL. But I have lived all over the U.S. |
| Back to top |
dej(Jed) Tractor Expert
Posted: Wed Jan 09, 2013 10:13 am Post subject: Re: 1953 Wd45 electrical |
| old wrote: | | (quoted from post at 21:06:02 01/08/13) No I live in Missouri but was born in Alabama LOL. But I have lived all over the U.S. |
Chill out guys. Heck, guys are even building tie down barckets so they don't scratch the paint jobs. Come on scratch the paint jobs. OMG already
get a life. |
| Back to top |
