| Author |
Message |
bobs old iron Tractor Expert
Posted: Sun Jan 06, 2013 10:26 pm Post subject: timming still not right |
ok, been working on and off for a time,,can't get timming right, other club members trying to help,, is their any one/place that i can get the info/pics on the firing order on my oliver cle-trac h-g,,, thanks bob |
| Back to top |
AJ. Long Time User
Posted: Tue Jan 08, 2013 8:57 am Post subject: Re: timming still not right |
I believe those machines had a Hercules flat head engine,if that's what you got the firing order is 1-2-4-3, #1 is at the front end, remove the four spark plugs, you now need to remove the mag cap, turn the engine in its normal direction of rotation by hand and note the direction the rotor turns, now block the #1 plug hole with your thumb and turn the engine till you feel the compression against your thumb,the engine is coming up on compression stroke of #1 cylinder,the flywheel timing mark should come into view in the timing hole on the bell housing,set the mark to the pointer, now check where the rotor is pointing to in the mag cap,that lead should go to #1 cylinder. the next lead in the direction the rotor turns goes to #2 cylinder, then the next to #4 and the last to #3.with the points clean and gapped correctly put the cap back on,put in the plugs and try for a start.
Good luck
AJ |
| Back to top |
Posted: Fri Jan 11, 2013 11:46 pm Post subject: Re: timming still not right |
thanks a-j, seams like never ending battle trying to get it to run... |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
