| Author |
Message |
BushogPapa Tractor Guru
Posted: Mon Jan 07, 2013 10:12 am Post subject: Rebuild Onan Carb..???? |
I have several Bolens 17 and 18 HP Garden Tractors that all get used regular and steady...
The old "QT 17" has an Onan engine and needs either a re-Build kit or a replacement Carburetor..
NAPA does not have the Kits (and WOW, the Prices.!)
Could anyone help me find these parts..??
I cannot get the Needle to work properly..it either wants to Flood or Starve to the point it quits..
I tried an Electric fuel pump and it flooded (4lb)..
I have worked on the Needle TIP and worked it to a good taper, like it should have been. (Rubber tip)..
Any suggestions about another carburetor to use..?
This engine is a REAL Powerhouse..I have the Large-Bore Commercial engine block and want to USE it more..!!!
Thanks..!
Ron. |
| Back to top |
Ken Combs Regular
Posted: Mon Jan 07, 2013 10:15 am Post subject: Re: Rebuild Onan Carb..???? |
Try Onanparts.com. |
| Back to top |
Posted: Mon Jan 07, 2013 10:39 am Post subject: Re: Rebuild Onan Carb..???? |
Thanks a bunch...!!
This is going to Help..!
Ron. |
| Back to top |
Harvey 2 Regular
Posted: Mon Jan 07, 2013 10:49 am Post subject: Re: Rebuild Onan Carb..???? |
Parts for Onans have allways been overpriced and they aren't getting any better.
One stop gap measure would be to install a inline fuel shut off and adjust the flow to a trickle,that might work. I bought a Cub Cadet several years ago and wondered why it had two shut offs on it, then I found out the carb always wanted to flood. I installed a new float and adjusted it, that stopped the flooding, wasn't even the needle and seat after all. |
| Back to top |
danc11358 Guest
Posted: Mon Jan 07, 2013 12:09 pm Post subject: Re: Rebuild Onan Carb..???? |
Hi.I have A Case 446 with A 16 H.P. Onan. Got carb. kit from Gary's place. Good service good price. |
| Back to top |
Ken Combs Regular
Posted: Mon Jan 07, 2013 3:26 pm Post subject: Re: Rebuild Onan Carb..???? |
I forgot to mention: check your float before ordering parts, and if it is a foam version, order a brass one along with the needle and gaskets. foam + alcohol = frustration! |
| Back to top |
Harvey 2 Regular
Posted: Mon Jan 07, 2013 4:00 pm Post subject: Re: Rebuild Onan Carb..???? |
Where is this Garys place ? I would like to buy some parts, if they are reansoble. |
| Back to top |
danc11358 New User
Posted: Mon Jan 07, 2013 4:11 pm Post subject: Re: Rebuild Onan Carb..???? |
Gary's Place 1068 E. Hull Rd.Hope Michigan 48628 Tel.989-689-5092. |
| Back to top |
Billy Shafer Tractor Expert
Posted: Mon Jan 07, 2013 4:26 pm Post subject: Re: Rebuild Onan Carb..???? |
Try Max Thompson. Over on Smokstak Onan section. He just bought the inventory of a Onan dealer. He may have a kit. |
| Back to top |
Posted: Tue Jan 08, 2013 7:32 pm Post subject: Re: Rebuild Onan Carb..???? |
Where is "Smokestak"..??
I will look for an "Onan Section"..
Thank you..
Ron.. |
| Back to top |
Harvey 2 Regular
Posted: Wed Jan 09, 2013 9:31 am Post subject: Re: Rebuild Onan Carb..???? |
Thanks a bunch on the location and phone # for Garys Place.
This is what the forum is all about, people helping one another.
Thanks again; |
| Back to top |
Posted: Sun Jan 13, 2013 12:29 pm Post subject: Re: Rebuild Onan Carb..???? |
It is smokstak. |
| Back to top |
kevinsstuff Regular
Joined: 09 May 2010 Posts: 28 Location: S.E. Wisconsin
Posted: Wed Jan 16, 2013 7:49 am Post subject: Re: Rebuild Onan Carb..???? |
i just ordered a gasket kit for my onan 16hp for my case 446 got the parts from cummins service center. cummins is the place to get your high priced service parts for your onan |
| Back to top |
Posted: Wed Jan 16, 2013 12:45 pm Post subject: Re: Rebuild Onan Carb..???? |
Thanks. everyone for this information..!!!
Ron.. |
| Back to top |
