Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Update on 2N not starting (Got it running)
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
wsmm
PostPosted: Mon Jan 07, 2013 3:45 pm    Post subject: Update on 2N not starting (Got it running) Reply to specific post Reply with quote
Used a spark plug with a 1/4" gap laid plug on the block and got a nice bright sharp white / blue spark. Tried starting fluid in the carb opening, no go. Then tried holding hand over carb opening to check for vacuum, string vacuum. After another shot of starting fluid and by adjusting my hand over the carb intake, I go it to fire and run. Let it run for awhile and then shut it down. Decided to check the condition of the oil bath air cleaner. To my surprise somehow condensation or water got in and the bottom of the oil bath was filler with a light brown slush! Cleaned out the cup and applied some heat from a lamp to the rest of the cleaner to melt out the rest of the slush. What grade oil do you run in your air cleaner during the winter. I have been running straight 30w year round. Thinking of running a paper filter during the winter and then switching back to the oil bath for spring through fall.
Royse
PostPosted: Mon Jan 07, 2013 4:02 pm    Post subject: Re: Update on 2N not starting (Got it running) Reply to specific post Reply with quote
I like the oil bath better than paper. I think they clean better.
I run whatever I'm putting in the engine in the oil bath, just to keep it simple.
HCooke
PostPosted: Mon Jan 07, 2013 4:13 pm    Post subject: Re: Update on 2N not starting (Got it running) Reply to specific post Reply with quote
Oil bath filter is more efficient than a paper filter. Tractors were originally designed to run in a very dirty environment. Save the money you would spend on converting it for something else. Use the same oil that you put in the engine.
Colin King
PostPosted: Mon Jan 07, 2013 5:25 pm    Post subject: Re: Update on 2N not starting (Got it running) Reply to specific post Reply with quote
Glad to hear that you got the 2N running! I also would choose the oil bath over a paper filter. Both require maintenance. Every time you change the oil, drain and thoroughly clean out the oil bath cup and add new oil. Condensation can get in the cup and cause the situation you experienced.
Colin, MN
old
PostPosted: Mon Jan 07, 2013 5:33 pm    Post subject: Re: Update on 2N not starting (Got it running) Reply to specific post Reply with quote
Very common for you to find water and dirty gue in the air cleaner cup and that is why it should be services every 10 hours of run time as per the NAA manual. Should be close to the same for your 2N. Oil bath for a tractor is far better then any paper filter will be.
