Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
OT cleaning off burnt on oil and grease
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Britcheflee
PostPosted: Mon Jan 07, 2013 5:20 pm    Post subject: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
I have collected about 20 saute pans which were on the way to the dumpster - I was going to take them to recycling as they are aluminium - however when I got them home I realized they are only dirty and need a clean - the stuff on them is burnt on grease and oil from years of use - the backs are really bad with that shiny brown glaze - the insides are bad but the bottoms are not so dirty - I tried a wire brush first - nothing, wire brush on drill, nothing, round grinder, just clogged it with goop, I have a pint of Berrymans cleaning stuff inside it and going to let it soak overnight - I am thinking that if I can get them back to shiny new I could actually sell them for more than recycle - also made me wonder if there might be a market for restaurants where I go and clean the pans back to new for them - do you think sandblasting would work? Any other cleaner you think might get that stuff off?
Lee
Den N Ms
PostPosted: Mon Jan 07, 2013 5:30 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
Britcheflee Use some cheap oven cleaner on them to remove the carbon burnt on gunk. Or even some paint remover will work great.
Ron-MO
PostPosted: Mon Jan 07, 2013 5:31 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
In a previous life at work we had a furnace we used for heat treating, and on occasion we would "burn off" items like that. I recall doing a lot of paint stripping that way, as well as cleaning items such as you mention. I think that small electric furnace (fire brick lined) ran roughly 1000 degrees and would make short work of cleaning things up. Simply wash off the ash that was left, then we usually bead blasted it, and refinished (on painted items). Probably not very environmentally friendly, and I often wondered about how exposive the fumes coming off it, but worked good. How hot does a gas bbq run? (I use charcoal, so I have no idea)
old
PostPosted: Mon Jan 07, 2013 5:36 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
I would still recycle them since I do not use aluminum cook ware at all due to the health risk ya it maybe a myth but I'll stay with my cast iron stuff
HCooke
PostPosted: Mon Jan 07, 2013 5:46 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
Oven cleaner (Lye, NaOH) and aluminum are a bad combination.
Britcheflee
This is probably what 99% of your food is cooked in at a restaurant:
http://www.instawares.com/gatorgrip-aluminum-fry-pan.971138.0.7.htm
Actually, because of the amount of oil and grease which builds up and seasons the pan I really doubt much aluminium ever gets into the food - boiling products in large aluminium pots may be a different story though.
Lee
I will try the oven cleaner and see if that works. Wouldnt an aluminium pan melt at 1000 degrees!!!
HCooke
PostPosted: Mon Jan 07, 2013 5:56 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
No oven cleaner on aluminum. Look up NaOH vs
Aluminum.
old
PostPosted: Mon Jan 07, 2013 6:08 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
Would you believe I might eat out once maybe twice a year?? Things like tomato's it is not good to cook in aluminum and any other high acid food. All my cook ware and yes I call it may because I do 99% of the cooking is cast iron or stainless steel or glass
Den N Ms
PostPosted: Mon Jan 07, 2013 6:36 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
Most oven cleaner is only 10% NaOH
Ron-MO
PostPosted: Mon Jan 07, 2013 6:43 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
No, aluminum (good grade) will not melt at 1000 degrees. The furnace we were using was used primarily to heat treat cast aluminum and laminated steel parts for manufacturing electrical components. We often went as high as 1200 degrees without melting the aluminum, and shrink fit the part onto an assembly using that method. But I am sure you could likely burn off those with a gas bbq as well at much less than 1000 degrees. "Pot metal" or some alloys will melt at those temps.
Bob Harvey
PostPosted: Mon Jan 07, 2013 7:25 pm    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
Your intent is good. However, JUNK them (or recycle) The effort to reclaim is NOT worth it.
Cliff(VA)
PostPosted: Tue Jan 08, 2013 5:06 am    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
It will still eat away at the aluminum and create LOTS of explosive hydrogen gas.
Cliff(VA)
TheOldHokie
PostPosted: Tue Jan 08, 2013 6:27 am    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
Britcheflee wrote:
(quoted from post at 21:20:00 01/07/13) I have collected about 20 saute pans which were on the way to the dumpster - I was going to take them to recycling as they are aluminium - however when I got them home I realized they are only dirty and need a clean - the stuff on them is burnt on grease and oil from years of use - the backs are really bad with that shiny brown glaze - the insides are bad but the bottoms are not so dirty - I tried a wire brush first - nothing, wire brush on drill, nothing, round grinder, just clogged it with goop, I have a pint of Berrymans cleaning stuff inside it and going to let it soak overnight - I am thinking that if I can get them back to shiny new I could actually sell them for more than recycle - also made me wonder if there might be a market for restaurants where I go and clean the pans back to new for them - do you think sandblasting would work? Any other cleaner you think might get that stuff off?
Lee
Sounds like a good job for the bead blaster to me. Or some agressive polishing compound and a HD buffer. Lye based oven cleaner and aluminum cookware do not play well together. It may remove the grease but you will not like the surface it leaves behind.
TOH
showcrop
PostPosted: Tue Jan 08, 2013 7:19 am    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
Unless it changed over the weekend, and I could call into the plant and check, NaOH is still what is being used at food service operations to clean burned on grease. And yes they are cleaning aluminum pans. I have customers who sell concentrated oven cleaner in 55 gal. drums to restaurants. I sell the 55 gal. drums to the distributors. Most restaurants don't keep up with them and the bottoms get very crusted, but some places do and during the cleaning they avoid getting it on the inside. but even if the cleaner etches the aluminum a little, a quick scrub removes the oxidation and shines the surface again.
TheOldHokie
PostPosted: Tue Jan 08, 2013 7:45 am    Post subject: Re: OT cleaning off burnt on oil and grease Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 11:19:56 01/08/13)
It WILL etch the surface and the stronger the lye content the deeper and faster the "etch". Don't leave it on more than a few minutes or the surface will start to pit and you will need a LOT of polishing to get it smooth again. That said I clean large commercial aluminum oven pans on a regular basis using the commercial oven/grill/fryer cleaner sold in pump botttles at Sam's Club. It's an inexpensive lye based cleaner that is very effective on stainless and works fine on aluminum if you work fast and don't mind the dull finish it leaves behind. I try to limit it to the exterior surfaces on aluminum cookware to protect the cooking surface. Do not use it on anodized Calphalon surfaces - it will destroy them almost instantly.
TOH
Goto page 1, 2  Next
Page 1 of 2
