Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1570 case tractor
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
Al.E
PostPosted: Tue Jan 08, 2013 8:53 pm    Post subject: 1570 case tractor Reply to specific post Reply with quote
Rod I come right of the pump into my 3 spool in the cab for the loader. but a flow meter on back remote and not good. get back to you.
1370rod
PostPosted: Tue Jan 08, 2013 9:21 pm    Post subject: Re: 1570 case tractor Reply to specific post Reply with quote
If the 3 spool valve is hooked in directly after the pump that valve has to have its own relief valve in it. That could be at fault, but the pump maybe also. You will not know for sure unless you have the pump flow tested. Also is your filter pressure gauge in the normal green zone when the tractor is running? Rod.
mEl
PostPosted: Wed Jan 09, 2013 4:21 am    Post subject: Re: 1570 case tractor Reply to specific post Reply with quote
A flo test of the pump is the first thing to do, It must be done by a trained technician as a pump can be totally destroyed by improper testing, I have tested many by simply hooking the flometer from the pump output to sump but that must be done with knowlege as there is no relief and a safe pressure at test cannot be exceeded. A Tee test is safer as the factory relief is in play but a pump only test can be safely done.
It is dangerous to add valves between the pump output and the original factory hookup unless one knows how tht valve is protected internally and a line to drain the installed valve is installed. the reason is that the valve installed will have full system pressure internally in areas of the valve that were not designed to. This happens when the tractor system is used in a normal manner and system pressure backs into the added valve with no sump return.
A drain line is essential to keep spool seals and other lo pressure areas protected.
mEl
1370rod
PostPosted: Wed Jan 09, 2013 5:15 am    Post subject: Re: 1570 case tractor Reply to specific post Reply with quote
Thanks Mel, I agree completely, Rod.
