| Author |
Message |
the Unforgiven Guest
Posted: Wed Jan 09, 2013 8:53 am Post subject: JD planter vs. IHC hydraulics |
Do you have to do anything to the tractor, in this case a 966, to use the single hydraulic line for the lift and the markers? Seems more like an old one-way system? Can you just plug in one side and go? |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6406 Location: Delta,colorado
Posted: Wed Jan 09, 2013 1:04 pm Post subject: Re: JD planter vs. IHC hydraulics |
Yes,no problem. |
| Back to top |
Bob Bancroft Tractor Expert
Posted: Wed Jan 09, 2013 1:15 pm Post subject: Re: JD planter vs. IHC hydraulics |
I am not familiar with a JD planter that only has one hose? What model is it? |
| Back to top |
JMS/.MN Tractor Guru
Posted: Wed Jan 09, 2013 4:29 pm Post subject: Re: JD planter vs. IHC hydraulics |
Check your Operator manual- some tractor companies recommend using a certain side for just one hose..........even tho either might work. JD is that way. |
| Back to top |
Posted: Wed Jan 09, 2013 4:43 pm Post subject: Re: JD planter vs. IHC hydraulics |
It's my "new" 7000 8rW, pull type, finger pick-up. The lift uses one hose running to a "master" cylinder, and the markers use a single hose too.
Now I must admit that I know very little about this planter, just got it unloaded and still setting it up, but I'm about sure that the lift had a single hose. Could very easily be wrong! Thanks guys!! |
| Back to top |
Posted: Wed Jan 09, 2013 5:04 pm Post subject: Re: JD planter vs. IHC hydraulics |
Nope, not familiar with that one.
I will add though- usually when you're running one way systems with a two way valve, they want you to have the capability to put the valve into "float", so you're not spiking pressure in the system by dead-heading one side of the valve all the time.
I initially asked because recent JD planters are apt to have an odd number of hoses. Mine has 5. Even my neighbors', which is still a finger pickup planter, has the extra "return" hose going directly into the tractor sump. |
| Back to top |
IaGary
Joined: 14 Jun 2007 Posts: 7238 Location: North Liberty Iowa
Posted: Wed Jan 09, 2013 8:06 pm Post subject: Re: JD planter vs. IHC hydraulics |
I don't know for sure but are you sure that the markers aren't activated through that master cylinder and the two hoses are hooked to the master cylinder making it a 2 way.
Gary |
| Back to top |
Loosehandle Regular
Posted: Wed Jan 09, 2013 8:28 pm Post subject: Re: JD planter vs. IHC hydraulics |
Yes,just make sure you get it down all the way. |
| Back to top |
Posted: Thu Jan 10, 2013 5:26 am Post subject: Re: JD planter vs. IHC hydraulics |
OK Gary, I will check that out, I knew they had some markers that were operated by the lift. The hydraulic hoses have not been fooled with, just wadded up a little. |
| Back to top |
Posted: Thu Jan 10, 2013 10:26 am Post subject: Re: JD planter vs. IHC hydraulics |
You can set it up with a separate hose just for the markers....nice if you want to control the markers separatly. |
| Back to top |
gbs Long Time User
Posted: Thu Jan 10, 2013 4:31 pm Post subject: Re: JD planter vs. IHC hydraulics |
all the 7000's i've used had 2 hoses for dual action,but they will work off single too,either way they work best if used with a float position valve so the drive wheels always stay in contact with the ground especially with hold springs on the planter boxes for no-till also when the planter is lowered the row markers will lower on their own without tripping the hyd.valve back to neutral |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
