| Author |
Message |
Matt E. Regular
Joined: 04 Dec 2011 Posts: 134 Location: Springfield, MO
Posted: Thu Jan 10, 2013 4:39 pm Post subject: The collection has started... |
and we will be picking up tractor #2 out of the bushes come Sunday! My tractor partner in crime Travis (Niece's husband) heard about an H sitting out in the woods about 5 miles from his house. The friend came across it when he was looking for a bull that got out. He talked to the owner about his lost bull and briefly about the tractor. Sam said to go talk to the old guy and he might give it to us for a little of nothing.
Well, Travis got to go look at it today and the man asked $200 for it! Done deal. It hasn't been run for 6-7 years. Was parked at the edge of the field because a wheel bearing in the front went out and he didn't take the time to mess with it.
Hopefully it isn't stuck but who knows. Has a good muffler and a rain flapper so cross my fingers. Have to cut a few saplings out of the way and drop the brush hog. Hopefully the other three tires all come up. One rear is still partially up. Lots of ifs but for $200 I'll take the chance.
Doesn't look too beat up. Can't wait to get our hands on her!
Anyone want to take a guess on the year? I'll get the serial number on Sunday and some more pictures posted. Whoo Hoo!!! (Farmalls get me excited for some reason. ) |
| Back to top |
TWheat Regular
Posted: Thu Jan 10, 2013 4:54 pm Post subject: Re: The collection has started... |
Just a guess, 1942 |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Thu Jan 10, 2013 5:02 pm Post subject: Re: The collection has started... |
Looks like really good deal. If you find it is in too bad shape you
can part it out for several times your investment, but it looks like it
is in nice enough shape to be worth saving.
Zach |
| Back to top |
AL Moyer in Pa. Regular
Posted: Thu Jan 10, 2013 5:15 pm Post subject: Re: The collection has started... |
I'll guess a 1950. |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5457 Location: SE Wisconsin
Posted: Thu Jan 10, 2013 6:14 pm Post subject: Re: The collection has started... |
Worth $200 for sure. |
| Back to top |
rhtx55 Long Time User
Joined: 15 Apr 2011 Posts: 642 Location: Republic of Texas
Posted: Thu Jan 10, 2013 6:17 pm Post subject: Re: The collection has started... |
Front grill is worth more than you paid !! Good luck !! |
| Back to top |
Matt E. Regular
Posted: Thu Jan 10, 2013 6:31 pm Post subject: Re: The collection has started... |
I really don't think we'll need to part her out. The guy said it was a good tractor and ran well. I just hope it isn't stuck badly. Suggestions prior to trying to turn it over? Pull each plug and squirt some ATF in each hole to soak for a while?
Its in a lot better shape than the B we paid $300 for and that one was stuck. Had to replace the manifold but with a set of rod bearings and a head job we got that one running as well. Going to put a new set of front tires on that one this weekend too. |
| Back to top |
Posted: Thu Jan 10, 2013 6:46 pm Post subject: Re: The collection has started... |
Pull the plugs, pull the starter and see if you can use the flywheel teeth and a good prybar type large screwdriver to turn it either or both ways, if it moves you are in luck. You might get it to start..... fresh gas, clean plugs and a fully charged battery.
If not, then I would squirt quite a bit of kerosene in each cylinder, wait a few days, then try to move the flywheel again, and so on and so on. Kerosene is good at breaking down rust, and freeing up stuck rings ( to a point).
But you have to consider the rods, mains, and valve train also, rust in those places are hard to get to until you get it home, a fencerow is not very handy place to remove much more.
If you can't get it to move at all with the prybar, best to put the plugs & starter back in and plan on winching it up on the trailer, get it home, and hopefully in the shop, and start the above process from there. |
| Back to top |
Matt E. Regular
Posted: Thu Jan 10, 2013 7:35 pm Post subject: Re: The collection has started... |
We have a trailer but I'm not sure if it will fit inside the fenders. Have to see how wide the rears are set on Sunday.
I forgot about pulling the starter to move the ring gear. We'll give it a shot. Yes we have a shop to work in thankfully.
| Back to top |
BOB HAWBECKER Regular
Posted: Thu Jan 10, 2013 8:18 pm Post subject: Re: The collection has started... |
save that one,dont part her out
looks good from here,but i see the left front wheel bearing cap is gone.
you can do this! |
| Back to top |
Matt E. Regular
Posted: Thu Jan 10, 2013 8:35 pm Post subject: Re: The collection has started... |
Yup, wheel bearing is shot on that side. That's why it was parked. She'll run again. May not take much of nothing. |
| Back to top |
mike1972chev Long Time User
Posted: Fri Jan 11, 2013 3:24 am Post subject: Re: The collection has started... |
GOOD DEAL!
I am ALSO saying FIRST pull all plugs,take air blow out cylinders and add lube(oil,kero,ect)and let it soak BEFORE trying to just start cranking it over!
That lube will make it into the oil pan,so be sure and change out the oil a few times. |
| Back to top |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6758 Location: Mitchell, SD
Posted: Fri Jan 11, 2013 4:02 pm Post subject: Re: The collection has started... |
Easiest way to turn it over is with the crank, or a small pipe wrench ahead of the lower pulley. |
| Back to top |
Too Far Gone Long Time User
Posted: Fri Jan 11, 2013 9:01 pm Post subject: Re: The collection has started... |
Its definitely after WW2,AND i SEE A FEW LITTLE THINGS THAT INDICATE 1949-1952 Range,like the start button bracket mouted up on the pipe higher for hand use,and the air cleaner cap is later if its original.Does it have a nice roller on the drawbar,or a flat strap? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
