Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
MF 231 injection pump problem
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
Roy G
PostPosted: Thu Jan 10, 2013 6:18 pm    Post subject: MF 231 injection pump problem Reply to specific post Reply with quote
Working on a 231 for a friend. He bought tractor running but had a lot of blowby and hard to start. Took it apart, had broke rings and a blown head gasket probably from ether. Took pump off for engine rebuild and now that I have put back on, can get no fuel to injectors. Cleaned out tank and screen on cutoff valve,blew out all lines and a new fuel lift pump. Injector pump is full of fuel and I know I have it bled of all air but all I get is a dribble of fuel at injector lines. I also know I timed pump correctly when I put timing gears back on. Anybody got any ideas? I'm 60 years old and I've been working on these old tractors for years. I'm thinking something is wrong in the injection pump but was running when drove into my shop. Any comments appreciated. Thanks.Roy G
DoubleR
PostPosted: Thu Jan 10, 2013 6:43 pm    Post subject: Re: MF 231 injection pump problem Reply to specific post Reply with quote
Did you take the plastic pet-cock on the bottom of the fuel tank apart and clean the crud out of it. I have to on my 231 every few years. It will start acting like its running out of fuel when working it hard. It will restrict the amount of fuel that is able to flow through. Just a suggestion.
Dieseltech
PostPosted: Thu Jan 10, 2013 6:51 pm    Post subject: Re: MF 231 injection pump problem Reply to specific post Reply with quote
If pump has not been used recently metering valve and/or plungers may be stuck from setting while engine was being repaired. Just mailed one back that had the same trouble. How long has it been since the engine ran last?
Mike tn
PostPosted: Thu Jan 10, 2013 8:08 pm    Post subject: Re: MF 231 injection pump problem Reply to specific post Reply with quote
Roy G - i'm no where near the mechanic you are but try taking off the output line on that new fuel lft pump and make sure it's pumping out enough fuel. I have had problems with new ones.
Fergie Bach
PostPosted: Fri Jan 11, 2013 2:24 am    Post subject: Re: MF 231 injection pump problem Reply to specific post Reply with quote
Once in a while the only way to generate enough "force" is to give the tractor a good hard pull up and down a road. Perhaps with one injector pipe slackened.
You seem to have covered everything really. Let us know what happens.
Roy G
PostPosted: Fri Jan 11, 2013 5:03 pm    Post subject: Re: MF 231 injection pump problem Reply to specific post Reply with quote
Guys, thanks for all your answers. The pump has been sitting on a shelf for about a year now. I suspect as dieseltech said something has probably stuck in pump. With bleeder plug out of side of pump body, when you turn over engine shoots out plenty of fuel. I had thought of pulling it to try and start. When ground dries up a little here I will round me up a helper and give that a try. Thanks for all replies
dgerth
PostPosted: Sat Jan 12, 2013 8:58 am    Post subject: Re: MF 231 injection pump problem Reply to specific post Reply with quote
Just an idea, perhaps plugged return line. Had this happen before.
dg
Dieseltech
PostPosted: Sat Jan 12, 2013 9:01 am    Post subject: Re: MF 231 injection pump problem Reply to specific post Reply with quote
If pump has not been run that long I am sure plungers and metering valve are stuck, and pull starting most likely won't work. Have repaired too many pumps in this condition, best to do a complete teardown and reseal. Just mailed back a 135 pump that had the same trouble. Good luck!
