Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
800 ford 12volt conversion what altenator to use.
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford
jmducks1
PostPosted: Thu Jan 10, 2013 6:46 pm    Post subject: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
800 ford what is the cheapest and easiest alternator to buy and what model vehicle and year from? Would i use a gm one wire or the older one from 1965 chevys? or is there a better one?
Royse
PostPosted: Thu Jan 10, 2013 6:52 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
Most use GM, like a 10si, they're cheap and available everywhere.
One wire or the three wire, either will work.
I like the 3 wire ones with the exciter wire.
It doesn't have to spin as fast to get started charging.
I don't have to tell the guys at my parts store what vehicle,
but late 70's early 80's Chevy pickup would probably work.
old
PostPosted: Thu Jan 10, 2013 7:00 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
You want an alternator for a 1980 Chev pick up truck. No power any thing No ac. If there is an O'Reilly's close by you can buy them for around $45 plus a $10 core and that is with a life time warranty. You will also need to 2 wire plug which is another $4 or so and a pack of Radio Shack diodes part #276-1661 silver line to the alternator side in the #1 wire on the plug
old
PostPosted: Thu Jan 10, 2013 7:02 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
Just to let you know has to be later then the 1974 I think 75 was the first year but could be the 74 that had the internal regulator. I always say 1980 since I am 100% sure on that since I also drive a 1980 Chev no power any thing no AC
jmducks1
PostPosted: Thu Jan 10, 2013 7:37 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
How do you wire a 1980 alt.? Some say to get a 2 wire plug
than take one of those wires and go back to the battery
terminal on the alt? Something like that? Or is that for the
1968 alt or so?
Royse
PostPosted: Thu Jan 10, 2013 7:42 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
That's the 3 wire alternator.
#2 pin wires to the battery terminal on the alternator.
#1 pin has the diode in it that Old mentioned coming from the ignition switch.
The diode keeps the alternator from feeding the ignition when you shut it off.
Without it, the tractor may keep running when you turn the key off.
old
PostPosted: Thu Jan 10, 2013 8:41 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
First off any alternator in the 60s and early 70s used an external V.R which you do not want. The ones on like I said a 1980 Chev pick up had the internal V.R which you do want. The 2 wire plug has markings of #1 and #2. The #2 goes to the bog stud on the alternator and what it is is the sensing wire for the VR which tells the alternator VR when to shut off. The #1 wire is how a person turns the excite circuit on. But you need the diode I told you about or the alternator can/will back feed the ignition so you can not shut the engine off
john in la
PostPosted: Fri Jan 11, 2013 3:30 am    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
Ford Hundred Series 12V Conversion
souNdguy
PostPosted: Fri Jan 11, 2013 5:41 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
autozone 29$ if you have a core. or 10-15 more without.
forget the 4$ 2 wire plug.. spade terminals on wire work fine.
194 bulb or 1-3a diode is fine.
jmducks1
PostPosted: Fri Jan 11, 2013 6:09 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
Would this be easier with a one wire if I can get one for 36.oo? Can I use any of the wires that went to generator?
old
PostPosted: Fri Jan 11, 2013 6:13 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
Reason I say use the plug is that in the past I have had problems with the spade terminals getting bent and that in turn shorts out the alternator and lets the smoke out
old
PostPosted: Fri Jan 11, 2013 6:15 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
Problem with most 1 wire alternator is that it takes high RPM to make them start to charge and some love to cause a battery to drain if it sits for a long time
souNdguy
PostPosted: Fri Jan 11, 2013 6:45 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
you don't use the insulated female spade plugs? I do.. that's what they are for.. for sliding over male spades and then insulating them.
most GOOD wire terminal kits come witht he basic female spadesma nd the insulated female spades. I love em..
old
PostPosted: Fri Jan 11, 2013 6:58 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
Of course I also like the factory type plug since it ha the wires on them and that makes it easy to hook up as needed but the each there own
souNdguy
PostPosted: Fri Jan 11, 2013 7:06 pm    Post subject: Re: 800 ford 12volt conversion what altenator to use. Reply to specific post Reply with quote
i'm just not into buying a few dollar plug when i can make it for 10 cents of parts. I'm frugal. Smile more money I save on useless 4$ parts.. the more tractors I can save up and buy. Smile
Goto page 1, 2  Next
Page 1 of 2
