Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
lightweight radiator
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
Nick from MD
PostPosted: Thu Jan 10, 2013 9:00 pm    Post subject: lightweight radiator Reply to specific post Reply with quote
I want to put a light radiator in my wd 45. what would you all recommend as a good cheap one to put in it. this tractor will only be used for pulling.
showcrop
PostPosted: Fri Jan 11, 2013 5:41 am    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
Go to your local salvage yard and get one from a Honda or similar.
brentp4455
PostPosted: Fri Jan 11, 2013 8:33 am    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
or an oooooold chrysler minivan.
J Bronk
PostPosted: Fri Jan 11, 2013 10:18 am    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
I bought a reman rad for an "88 manual shift caravan for my Jd A. It works great and only cost $65.
6pack
PostPosted: Fri Jan 11, 2013 10:48 am    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
Works good
http://www.ebay.com/itm/Civic-EG-EK-SI-EG6-B16A-B16B-B16-Bolt-On-Aluminum-Radiator-Red-Radiator-Hose-/200876635058?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec52e33b2&vxp=mtr
perrycountyfarmalls
PostPosted: Fri Jan 11, 2013 2:55 pm    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
6pack,
do you currently use one of these radiators? what do you have it in, I'm considering something like this for my 460, but I want to make sure I have enough cooling.
thanks, Rusty
6pack
PostPosted: Fri Jan 11, 2013 3:17 pm    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
Oliver 88 w/320... Have the electric fan to run too, but not always on... 1 thing you have to do is, make it so any air that comes through grill HAS to pass through radiator.... I used card board and duct tape when I put it in to make a shroud around it, but now I ripped it all out to use aluminum sheet metal.... Oh! I am using a stock water pump, but I am gonna try an electric shur-flo? Rv pump of some sort... I will be putting it back together in a couple weeks and try to take a pic
There is an additive I use called 40 below that helps reduce water temp, i only noticed about 15 degrees cooler...I use that and just water... No thermostat just a 7/8 hole in a plate....
Look on ebay as there are some bigger hot rod radiators to use too, but cost a lot more
perrycountyfarmalls
PostPosted: Fri Jan 11, 2013 3:27 pm    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
I'll be about the same motor wise, and planned on an electric fan and stock waterpump also.
I run.. I think its called engine ice in my 4 wheelers...maybe something similar.
Thanks for the help!!
504
PostPosted: Fri Jan 11, 2013 4:29 pm    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
Toyota Corollas, around 85,86 use a center fill top tank.
showdown
PostPosted: Fri Jan 11, 2013 5:31 pm    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
I put a civic one in mine off e-bay, with the e-fan no thermo. This seems to work good, I haven't pulled it yet. You will have make some custom hoses cause the civic rad. is 1.25 dia. in and out lol..... $64.00 free frieght.
algar
PostPosted: Sat Jan 12, 2013 8:22 pm    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
I have found that the fan fromm a Ford Taurus HO has one of the highest cfm outputs tha helped my 6 cyl gas deere
jim johnson
PostPosted: Sun Jan 13, 2013 7:40 am    Post subject: Re: lightweight radiator Reply to specific post Reply with quote
You can take the radiator to any good radiator shop and they can change the inlets and outlets to what ever size and position you want, I did and the price was not very high. The one I used had the neck on the side and I had it moved to the center and also moved the return.
Jim
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
