Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Testing Briggs coil/Megafire module?
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
Aaron SEIA
PostPosted: Fri Jan 11, 2013 4:54 am    Post subject: Testing Briggs coil/Megafire module? Reply to specific post Reply with quote
Have a no spark issue on my AC B110. Has new coil, plug, and Mega Fire module. Is there a way to test any of this, or do I just throw parts at it until it sparks again? Probably doesn't have 10 hours on everything.
AaronSEIA
joe csuti
PostPosted: Fri Jan 11, 2013 1:55 pm    Post subject: Re: Testing Briggs coil/Megafire module? Reply to specific post Reply with quote
Disconnect kill lead to ign sw,crank eng & check for spark,if you have spark now then problem in wiring to ign sw from coil,ign sw bad or problem in safety sw's or wiring harness on tractor.
If still no spark with kill lead disconnected,check that connection from megafire module to eng block/chassis is clean/tight.After that check flywheel/coil air gap,manual says .010"-.014" or check instructions for megafire unit,air gap may have to be changed,after that goto link below & read instructions for setting flywheel timing as same is adjustable on 243000 series eng.
If after disconnecting kill lead,checking megafire ground connection & flywheel timing & you still have no spark,remove coil & take to one/more local mower shops & have them check in a coil tester,if coil tests ok,then problem may be one of the following:
1-Megafire unit bad due to heat/vibration depending on where same mounted on eng/tractor.
2-Flywheel magnets weak,this is a somewhat common problem on these old briggs eng,might try changeing flywheel/coil air gap if magnets the problem,you might be able to get around weak magnets this way.
flywheel
El Toro
PostPosted: Fri Jan 11, 2013 2:01 pm    Post subject: Re: Testing Briggs coil/Megafire module? Reply to specific post Reply with quote
Touch your magnets with a flatblade screwdriver to see if they have strong magnetism as Joe suggested. Hal.
FredinMO
PostPosted: Fri Jan 11, 2013 9:24 pm    Post subject: Re: Testing Briggs coil/Megafire module? Reply to specific post Reply with quote
Try reversing the wires on your mega chip some old cast iron briggs have a reverse polarity coil.
