| Author |
Message |
waldok1 New User
Posted: Fri Jan 11, 2013 5:46 am Post subject: W9 Magneto |
Does anyone know if the mag off of a M will work on a W9. |
| Back to top |
Bob M Tractor Guru
Posted: Fri Jan 11, 2013 6:30 am Post subject: Re: W9 Magneto |
Unfortunately no. An M magneto rotates the opposite direction from a W9. |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5375 Location: SE Wisconsin
Posted: Fri Jan 11, 2013 6:42 am Post subject: Re: W9 Magneto |
| Bob M wrote: | | (quoted from post at 07:30:06 01/11/13) Unfortunately no. An M magneto rotates the opposite direction from a W9. |
Are you sure? I thought just the diesels spun backwards. |
| Back to top |
rustred Tractor Expert
Posted: Fri Jan 11, 2013 7:00 am Post subject: Re: W9 Magneto |
you bet it will, same mag.
the diesel engines mag turns opposite direction due to an idler in the timing gears thats the only diff., so dont get the 2 mixed up. |
| Back to top |
Wardner Tractor Guru
Joined: 14 Dec 1999 Posts: 5373 Location: Tewksbury, MA 01876
Posted: Fri Jan 11, 2013 7:31 am Post subject: Re: W9 Magneto |
Rustred is correct. Diesel and gas ignition have the same rotation in the 9 series. They are opposite in the 6 series. This also applies to distributer pump selection. |
| Back to top |
Bob M Tractor Guru
Posted: Fri Jan 11, 2013 7:34 am Post subject: Re: W9 Magneto |
Yes. All the diesels and the W9 gas mags rotate opposite the other IHC magnetos. |
| Back to top |
El Toro Tractor Guru
Posted: Fri Jan 11, 2013 7:36 am Post subject: Re: W9 Magneto |
Here's the rotation on mags and distributors. Hal
| Back to top |
Posted: Fri Jan 11, 2013 8:42 am Post subject: Re: W9 Magneto |
oh oh, the original answer is NO not yes as i said. w9 is opposite an m rotation, same thing and diff all at same time. |
| Back to top |
n9lhm Regular
Posted: Fri Jan 11, 2013 8:51 am Post subject: Re: W9 Magneto |
Note that the advance is different on the CCW mags between the gas and diesel 9 series applications -- the gassers take a 35 degree advance impulse coupling and the diesels take a 15 degree advance. |
| Back to top |
| rustred wrote: | | (quoted from post at 09:42:52 01/11/13) oh oh, the original answer is NO not yes as i said. w9 is opposite an m rotation, same thing and diff all at same time. |
Will a diesel mag work? |
| Back to top |
Posted: Fri Jan 11, 2013 9:13 am Post subject: Re: W9 Magneto |
basically yes the diesel m mag will work on his w9 but have less advance, as noted. |
| Back to top |
Posted: Fri Jan 11, 2013 9:26 am Post subject: Re: W9 Magneto |
| rustred wrote: | | (quoted from post at 10:13:45 01/11/13) basically yes the diesel m mag will work on his w9 but have less advance, as noted. |
Sorry, the advance post wasn't there before I started typing. I was thinking there woudl be advance issues if you used a diesel mag. |
| Back to top |
Posted: Fri Jan 11, 2013 10:31 am Post subject: Re: W9 Magneto |
.Deleted
| Back to top |
n9lhm Regular
Posted: Fri Jan 11, 2013 12:30 pm Post subject: Re: W9 Magneto |
Mark"s Magneto Service will exchange the 15 degree impulse cup for a 35 degree one for a nominal price. I did that with a W9 gas mag that I had so I would have a complete spare mag for my MD. |
| Back to top |
