Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
No drive
Post new topic    Yesterday's Tractors Forum Index -> Ford
Fire/Farm
PostPosted: Fri Jan 11, 2013 12:00 pm    Post subject: No drive Reply to specific post Reply with quote
I have no drive at all in and gear. I was blading the driveway and suddenly the power to the rear wheels was lost. I can shift through all gears and none works. It seems like it wants to go in r2, 3, and 4, but won"t. The fluid is full and fairly clean. What can I do?
Fire/Farm
PostPosted: Fri Jan 11, 2013 12:07 pm    Post subject: Re: No drive Reply to specific post Reply with quote
Sorry forgot to mention its a 59" 881.
Sean in PA
PostPosted: Fri Jan 11, 2013 12:22 pm    Post subject: Re: No drive Reply to specific post Reply with quote
Did you check the traction disconnect?
Fire/Farm
PostPosted: Fri Jan 11, 2013 12:29 pm    Post subject: Re: No drive Reply to specific post Reply with quote
Yes I did. The trans is locked up but no drive.
Dean
PostPosted: Fri Jan 11, 2013 12:50 pm    Post subject: Re: No drive Reply to specific post Reply with quote
Does the PTO work properly?
Dean
Larry NCKS
PostPosted: Fri Jan 11, 2013 12:51 pm    Post subject: Re: No drive Reply to specific post Reply with quote
Most likely cause is failure of the TLC (torque limiting clutch) This unit is in the tractor's flywheel so is a front split. It could be that the clutch hub itself broke loose or it could be that the splines on the input shaft and/or clutch hub wore out.
Check to see if your PTO will function at all. If not the above scenario is a very sure bet.
View user's profile AIM Address
Fire/Farm
PostPosted: Fri Jan 11, 2013 5:40 pm    Post subject: Re: No drive Reply to specific post Reply with quote
It actually started working again. It has done that before and it started working again after it sat awhile. It also seemed to help when I raised/lowered the pto. This time it sat for 2 days and this mornin it still didn"t work the first try. I read the manual for a while and tried it again. That time I throttled it up full and put it in 1. It didn"t go immediately but finally slid into gear. I still don"t know what went on.
Dean
PostPosted: Fri Jan 11, 2013 6:15 pm    Post subject: Re: No drive Reply to specific post Reply with quote
It's not fixed.
Problems will return.
Dean
Larry NCKS
PostPosted: Fri Jan 11, 2013 6:22 pm    Post subject: Re: No drive Reply to specific post Reply with quote
fire/farm wrote:
(quoted from post at 20:40:25 01/11/13) It also seemed to help when I raised/lowered the pto.
Raised/lowered the PTO ????????
That lets the TLC out. Sounds more now like a sticky valve in the control valve body or a leak that gets more exaggerated as the unit warms up.
Fire/Farm
PostPosted: Fri Jan 11, 2013 6:30 pm    Post subject: Re: No drive Reply to specific post Reply with quote
That"s what I was thinkin. I was also considering
the overrunning clutch or sticking bands.
Sean in PA
PostPosted: Sat Jan 12, 2013 5:02 am    Post subject: Re: No drive Reply to specific post Reply with quote
fire/farm wrote:
(quoted from post at 21:40:25 01/11/13) It also seemed to help when I raised/lowered the pto.
The PTO does not raise and lower. Do you mean raise/lower the 3 point lift? or engage/disengage the PTO?
reb-in-pa
PostPosted: Sat Jan 12, 2013 2:07 pm    Post subject: Re: No drive Reply to specific post Reply with quote
Guys -- I've only had one SOS apart (and it didn't survive the operation), but wouldn't intermittent failure of the pump in the trannie act like this? What if something occasionally blocked the pickup/intake for the pump?
