3588 AC question
youngin
PostPosted: Fri Jan 11, 2013 12:02 pm    Post subject: 3588 AC question Reply to specific post Reply with quote
We have 3588 with ac troubles. When the low pressure gauge gets to about 70 and high pressure to 50 it just runs until the high gets to 100 then the compressor shuts off. Then it wont kick on for a while. I have no juice at the yellow wire at the relay cut out. If i jump juice to that wire the compressor runs. Should their be juice their?
Owen Aaland
PostPosted: Fri Jan 11, 2013 4:26 pm    Post subject: Re: 3588 AC question Reply to specific post Reply with quote
Youngin wrote:
(quoted from post at 16:02:04 01/11/13) We have 3588 with ac troubles. When the low pressure gauge gets to about 70 and high pressure to 50 it just runs until the high gets to 100 then the compressor shuts off. Then it wont kick on for a while. I have no juice at the yellow wire at the relay cut out. If i jump juice to that wire the compressor runs. Should their be juice their?
What does the low side pressure read once the compressor starts?
There is a low pressure switch in the cab on the return hose from the evaporator and a high pressure switch near the condenser in front of the radiator. The low pressure switch should close at 6 +/- 2 psi. The high side switch should close at 375 +/- 10 psi. Both switches must remain open for there to be "juice" at the compressor clutch.
Pete, Thanks or catching the errors .
pete 23
PostPosted: Sat Jan 12, 2013 8:33 am    Post subject: Re: 3588 AC question Reply to specific post Reply with quote
Both switch's must remain open to operate. When they
close they operate the lockout relay , turn on red
light and cut power to compressor until power to
them is shut off so lockout relay can return to
power on to clutch.
Tristan in MN
PostPosted: Sat Jan 12, 2013 2:55 pm    Post subject: Re: 3588 AC question Reply to specific post Reply with quote
Another thing to check is how much freon you have in the system. check to see if there are bubbles in the sight glass when the compressor is running, if there is you need freon.
