Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
L water pump
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
jmohr
PostPosted: Fri Jan 11, 2013 5:15 pm    Post subject: L water pump Reply to specific post Reply with quote
I am in need of some help with my L water pump. It is leaking water out of the front. I have the front off and the felt seal is gone.
Do I have the pump rebuilt or do I just replace the seal? I hear the pump tends to be tough to get off, but I do want it right. Give. Your suggestions. I also need a place for the parts. Thank you.
D G Wells
PostPosted: Fri Jan 11, 2013 8:29 pm    Post subject: Re: L water pump Reply to specific post Reply with quote
Jmohr, The L water pumps should be like the LA water pumps in the way they reach into the block. There is the first flange in the front of the block and a second flange back about two inches. Both flanges get rusted to the block. If it does not come out readily here is a method that will work. Remove the pulley and the pump bolts. Put two of the bolts into the threaded holes in the front flange of the pump and tighten them slightly to put pressure against the block. Be gentle here as not to break the pump housing. Block off the lower water port of the block and fill the water jacket with diesel or similar oil enough to get above the water pump. Lightly tap around on the snout of the pump with a small hammer or a rubber mallet. Might take minutes or hours or days, but it will break loose. Have a five gallon bucket under the tractor to catch the diesel when it pours out. Happy soaking. I am including a picture of my first LA, and now I have done two; have learned a lot about them. ---Derrol in Texas---
fred goodrich
PostPosted: Sat Jan 12, 2013 7:03 am    Post subject: Re: L water pump Reply to specific post Reply with quote
I have never seen anything on a Case tractor as tough as anLA water pump to remove. I would locate a spare allready out before I attemp to remove another one.
Ron Sa
PostPosted: Sat Jan 12, 2013 6:04 pm    Post subject: Re: L water pump Reply to specific post Reply with quote
I fixed the water pump leak on my 1930 L and it was a real challenge. On my tractor there is no seal cartridge. The shoulder on the impeller contacts a mating bronze surface on the housing bushing to create the seal.
A radial bronze sleeve bearing at the rear supports the impeller and a double sealed ball bearing at the front that supports the belt tension radial load.
There is a vent hole in the bottom of the housing that allows any leakage to drain out and not get into the area of the ball bearing. If you are getting leakage out the front of the housing, is your vent hole corroded shut?
The OD of the ball bearing needs to remain a slip fit in the housing and not become rusted and stuck. A spring pushes forward on the OD of the ball bearing. This force keeps the seal surfaces under a load equal to the spring force. The ratating fan also pulls froward and helps keep the seal surfaces in contact.
My C water pump seal is like the L water pump seal. My DC pump is different than the C and probably the LA is different than the L--both later tractors having a cartridge seal. A DC water pump will not work on my C--too long. An LA water pump may not work on an L. I am not completely sure about that. Maybe someone else knows about the L and LA pump interchangeability.
TCM in Iowa rebuilt my pump for a very reasonable price. Can provide you more details if you are interested.
SO HOW DID I GET THE WATER PUMP REMOVED WITHOUT BREAKING THE HOUSING? I rounded up six small screw drivers and sharpened them to where the edge was thinner than the water pump gasket. With the radiator and the two elbows removed from the block, pound these six "wedges" in uniformly at the gasket. This is the same principle as splitting wood with steel wedges.
First, pound each wedge just enought that it will stick in place. DO NOT wedge againist any of the three ears because the ears are weak. place two wedges between each set of ears. Drive the six wedges in a little at a time--uniformly.
On my tractor, this method extracted the pump from the block. Once the pump starts to move and a small gap appears, start using penetrating oil down the gap and letting it soak for hours maybe a day.
The wedges created minor scuffs on the block face and the pump mounting face but a little fileing and gasket sealer took care to that.
Let me know if you decide to proceed. There is more that I can share with you but this is getting long.
casecollectorsc
PostPosted: Sat Jan 12, 2013 8:58 pm    Post subject: Re: L water pump Reply to specific post Reply with quote
I've got some early L's that when they start to weep, just grease with water pump grease and they tend to seal.
