| Author |
Message |
Mr. T. Minnesota Regular
Posted: Sat Jan 12, 2013 7:37 am Post subject: FEL Sudden drop under load ( update) |
Forum Members,
Thanks for the info of possible solutions on the FEL sudden drop N syndrome. Removed the shifter lever cover and ran the 8N this morning and found fluid gushing all over. First thought it was the piston, but found a large 1/2 by 1/2 inch section of gasket suspended in the mechanism of the top cover. I am going to replace it this morning.
Question is, is there something better than picture framing mat board to use as a gasket? The mat board is quite tough. Any thoughts are welcome.
Mr. T. Minnesota |
| Back to top |
HCooke Tractor Expert
Posted: Sat Jan 12, 2013 7:44 am Post subject: Re: FEL Sudden drop under load ( update) |
Because of the high pressure involved, I would use a ready made gasket (avail here at YT and other places). No gasket goop on that gasket either. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50425 Location: Lake of the Ozarks area of MO
Posted: Sat Jan 12, 2013 7:51 am Post subject: Re: FEL Sudden drop under load ( update) |
As H-Cooke said get the correct gasket or your going ot be doing it again very soon and it is not fun to do that job. Most any good NH/Ford dealer should have that gasket on hand. Even an O'Reilly's should be able to order you one or this site. I said a dealer first because you can get that today maybe |
| Back to top |
Posted: Sat Jan 12, 2013 10:34 am Post subject: Re: FEL Sudden drop under load ( update) |
HC,
Checked the parts department and found the gasket set. What am I going to do with all that mat board stored in the shop? Thought about inserting a modified copper grommet into the oil port opening of the gasket. Just a thought.
Have one more theory. My new theory is to wait for a lot of forum input before theorizing.
Mr. T. Minnesota |
| Back to top |
JMOR Tractor Guru
Posted: Sat Jan 12, 2013 10:43 am Post subject: Re: FEL Sudden drop under load ( update) |
| Mr. T. Minnesota wrote: | (quoted from post at 14:34:49 01/12/13) HC,
Mr. T. Minnesota | Unless the metal surfaces are damaged, the paper gasket has been the working solution to sealing those parts for over 70 years...no new "invention" needed now. |
| Back to top |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 5872 Location: Myersville, MD
Posted: Sat Jan 12, 2013 10:51 am Post subject: Re: FEL Sudden drop under load ( update) |
| Mr. T. Minnesota wrote: | (quoted from post at 14:34:49 01/12/13) Thought about inserting a modified copper grommet into the oil port opening of the gasket. Just a thought.
I'm thinking that grommet is a good recipe for a cracked top cover. It takes very little unevenness on the clamping surfaces to crack a flat casting like that.
TOH |
| Back to top |
JMOR Tractor Guru
Posted: Sat Jan 12, 2013 11:14 am Post subject: Re: FEL Sudden drop under load ( update) |
| TheOldHokie wrote: | (quoted from post at 14:51:08 01/12/13) | Mr. T. Minnesota wrote: | (quoted from post at 14:34:49 01/12/13) Thought about inserting a modified copper grommet into the oil port opening of the gasket. Just a thought.
TOH | That little "ckick" when you torque down on a cast iron part is a real downer!  |
| Back to top |
old Tractor Guru
Posted: Sat Jan 12, 2013 11:39 am Post subject: Re: FEL Sudden drop under load ( update) |
Correct gasket and NO type of gasket crude. Trying to fix what has worked for decades does not work with this area of this type/modal of tractor |
| Back to top |
Posted: Sat Jan 12, 2013 11:43 am Post subject: Re: FEL Sudden drop under load ( update) |
I've done a half doz of these. Just the paper gasket and no sealer. Use some 7/16" bolts with the heads cut off to hold the gasket in place while lowering the top cover into place. I also use a small wedge between the main draft spring and the rear end to hold the cover up while I re-position the control arm. |
| Back to top |
souNdguy Tractor Guru
Posted: Sat Jan 12, 2013 1:23 pm Post subject: Re: FEL Sudden drop under load ( update) |
dry paper oe style gasket.. nothing else.
the only other possible mod I would do is have the cover cut for an oring that then sandwiched down onto the deck.. I have seen a fergy with a deck cut oring boss.. etc.
still.. I've done plenty N with paper gasket and have never had to go back in as long as the deck and cover were clean and smooth there.
remember if you put a metal crush gasket around the port.. the cover will not set true, making the outside of the cover be at a different angle, and thus encourage blow out.
the engineers covered this by 1939.. no need to reinvent it. |
| Back to top |
Posted: Sat Jan 12, 2013 2:10 pm Post subject: Re: FEL Sudden drop under load ( update) |
| JMOR wrote: | (quoted from post at 15:14:02 01/12/13) | TheOldHokie wrote: | (quoted from post at 14:51:08 01/12/13) | Mr. T. Minnesota wrote: | (quoted from post at 14:34:49 01/12/13) Thought about inserting a modified copper grommet into the oil port opening of the gasket. Just a thought.
Sounds like you have had some personal experience along thes lines. Hope it was something cheap like a thermostat housing
TOJ |
| Back to top |
ASEguy Tractor Expert
Posted: Sat Jan 12, 2013 2:42 pm Post subject: Re: FEL Sudden drop under load ( update) |
I've done that. I also couldn't agree more with the possibility of a cracked cover. |
| Back to top |
| Back to top |
| Back to top |
