| Author |
Message |
wsmm Regular
Posted: Sat Jan 12, 2013 8:57 am Post subject: Metric drain plug in parts washer |
My parts washer has a M16 - 1.50 plug in it for draining. I'd like to put in a drain valve or some type of assembly or fitting that would allow me to drain it without removing just the bolt type plug and having it all run out at once with no control. Also don't need to get the solvent bath that happens when you first remove the plug. Any idea of what to use or where to purchase it at?
Bill |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5457 Location: SE Wisconsin
Posted: Sat Jan 12, 2013 9:37 am Post subject: Re: Metric drain plug in parts washer |
An auto parts store may have one for use in a car. Those quick drain plugs are more common in ag though so they are probably all standard. |
| Back to top |
DiyDave Tractor Guru
Posted: Sat Jan 12, 2013 4:44 pm Post subject: Re: Metric drain plug in parts washer |
Get a hose barb fitting, and put a hose in the drain port. You can get a hose barb shut off valve, and put that in the end of the hose, and then you would have absolute control of where it is pointing as it drains. |
| Back to top |
Russ from MN Tractor Expert
Posted: Sat Jan 12, 2013 5:17 pm Post subject: Re: Metric drain plug in parts washer |
Drill a hole all the way through the plug, as big as you dare! Then drill a 7/16 hole into the hex head and tap it 1/4 pipe thread. |
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10643 Location: Sanford, NC
| Back to top |
markiz41 Regular
Posted: Sun Jan 13, 2013 6:34 pm Post subject: Re: Metric drain plug in parts washer |
Use a 5 gallon bucket when draining it. Will fit neatly on the bottom shelf. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
