| Author |
Message |
Bob Purinton Regular
Posted: Sat Jan 12, 2013 11:02 am Post subject: Headlight wiring clips got me stumped |
Beautiful day here in the eastern panhandle of West Virginia so...
I wanted to get my headlights working on my "48 8N. I got "em working and need to hide wiring but I can"t figure out the little clips that hold the wiring up under the hood. Do they go on the hood somewhere or the support brackets for the gas tank? Also, I need to know the placement of the clips across to the rightside headlight.
Thanks. |
| Back to top |
Colin King Tractor Expert
Posted: Sat Jan 12, 2013 12:38 pm Post subject: Re: Headlight wiring clips got me stumped |
Bob;
What's worked for me is to run the right side between the grill and the radiator to the left side. Leave yourself a little slack for ease of working. I run both a positive and a negative.
The clip on my '47 was attached by drilling a hole in the dog-leg just below where it goes into the hood. It's kind of noticeable.
If I were putting clips in myself, I would drill two in the lip of the hood and mount the clips there. This would hide all of the hardware. You could also do this and use zip ties if you didn't have the clips. This way, everything would be nicely hidden from view, but still accessible.
Colin, MN |
| Back to top |
Royse Tractor Expert
Posted: Sat Jan 12, 2013 12:55 pm Post subject: Re: Headlight wiring clips got me stumped |
The lights were a dealer or owner installed option, so I don't think there's
any right or wrong place to put those clips other than being functional.
I clipped mine up under the hood just close enough together to keep the wire
from sagging.
I used stick on Velcro pads on the under side of the hood, and fastened the
cross wire to it with the other half of the Velcro.
I know its not what they dealer would have done, but its out of the way, removable and secure. |
| Back to top |
Posted: Sat Jan 12, 2013 1:24 pm Post subject: Re: Headlight wiring clips got me stumped |
I went and got the seven little clips that the dealer would've used and I have no idea how to get them to work.
I'm about to use some wire ties or something to fasten the wires out of the way; but, I'd rather have the clips in there since I got them.
The MPC or the FO4 manual neither touch this subject and there is nothing on this site about it either. At least that I could find.
Thanks for answering. |
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10611 Location: Sanford, NC
Posted: Sat Jan 12, 2013 7:47 pm Post subject: Re: Headlight wiring clips got me stumped |
| Bob Purinton wrote: | (quoted from post at 01:24:38 01/13/13) I went and got the seven little clips that the dealer would've used and I have no idea how to get them to work.
They clip to the underside of the hood are the hood frame... It should be obvious the clip clips over sum'n... |
| Back to top |
Posted: Sat Jan 12, 2013 8:25 pm Post subject: Re: Headlight wiring clips got me stumped |
Unless I missed some subtle hint as to what might have been a very eloquent answer to my question; I must wonder if Hobo's prescription meds have run out or his family tree doesn't fork.
How do the clips that hold the headlight wire attach to the hood or where ever they attach?
These clips are p/n 358297-S on page 160 of the MPC. On this site they are p/n 358297S7.
Thanks |
| Back to top |
Posted: Sat Jan 12, 2013 8:48 pm Post subject: Re: Headlight wiring clips got me stumped |
Trying to help, but didn't have a picture, so here's what I got.
Picture from this site.
Clips goes over the edge of the hood where the black line is.
Wire goes through where the red line is.
Curved end of the clip up and toward the outside of the hood.
At least that's how I put mine on, right or wrong.
I get frustrated with mine some times too, but Hobo isn't the cause.
| Back to top |
Posted: Sun Jan 13, 2013 7:25 am Post subject: Re: Headlight wiring clips got me stumped |
That's better than anything I came up with. The closest I came to this was putting the wire all the way in the bend and then pushing onto the lip of the hood. Needless to say; it didn't work.
Thanks for an intelligent response.  |
| Back to top |
| Back to top |
carolina don Regular
Posted: Sun Jan 13, 2013 8:38 am Post subject: Re: Headlight wiring clips got me stumped |
Bob.....on the 48 and early 49 8n models, four of the clips are attached to the lower panel of the front gas tank support.The wire ran from one light to the other by going OVER the upper radiator water connection with a clip connected on each side of the water connection and a clip at each extreme end of the gas tank support panel.The other three were evenly spaced from front to rear and connected to the bottom of the hood reinforcement on the right hand side of the hood.Things changed a little in late 49, but you say you have a 48.Hope this helps. don b |
| Back to top |
Posted: Sun Jan 13, 2013 12:56 pm Post subject: Re: Headlight wiring clips got me stumped |
Well, thanks, I appreciate it.
I didn"t know they were a "buy them anywhere any shape any size" type thing.
I"m not the sharpest tool in the shed sometimes or I wouldn"t need the forums, now, would I?
Thanks again. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
