| Author |
Message |
guido Tractor Expert
Posted: Sat Jan 12, 2013 11:30 am Post subject: Tool Challenge! |
Hello,
This feeler gauge used to be 12" long.
I have used 1/2 of it for other repairs. What would a 12" long feeler gauge set, sizes from .0015 to .015 be used to measure?
Guido.
| Back to top |
MisterT Long Time User
Posted: Sat Jan 12, 2013 11:44 am Post subject: Re: Tool Challenge! |
Was it an actual set of feeler gauges? Or was it individual pieces? If it was individual pieces, it may have just been an assortment of shim stock. |
| Back to top |
Posted: Sat Jan 12, 2013 11:52 am Post subject: Re: Tool Challenge! |
Hello Mister T,
There was a set that you could buy with the sizes i mentioned. I also had an assortment as well.
Guido. |
| Back to top |
Doc 2 Regular
Posted: Sat Jan 12, 2013 12:10 pm Post subject: Re: Tool Challenge! |
Feeler gauges like that are used to measure piston clearance during a rebuild. |
| Back to top |
Steve Reed Guest
Posted: Sat Jan 12, 2013 12:45 pm Post subject: Re: Tool Challenge! |
We used feeler gauge sets 12 inches long to set the gaps on doors on industrial furnaces. I'm talking about heat treat furnaces such as draws and carborizers. I believe Starret used to make them. |
| Back to top |
Welding man Long Time User
Posted: Sat Jan 12, 2013 1:36 pm Post subject: Re: Tool Challenge! |
If they had a hole in the end they were used with a set of spring scales to check piston skirt clearance on engine rebuilds. |
| Back to top |
Iowa Barber Regular
Posted: Sat Jan 12, 2013 2:11 pm Post subject: Re: Tool Challenge! |
We used long feeler gauges to adjust valves on the old 292 cid ford engines to keep from burning our hsnds on the exhaust manifolds. Brian |
| Back to top |
ASEguy Tractor Expert
Posted: Sat Jan 12, 2013 2:48 pm Post subject: Re: Tool Challenge! |
Hey Guido. The only brass ones I've seen in automotive were for setting reluctor gap on electronic ignition for Chryslers. Those were .010 if I remember corectly. .015? Got me. |
| Back to top |
Dick L Tractor Guru
Posted: Sat Jan 12, 2013 2:57 pm Post subject: Re: Tool Challenge! |
piston clearance |
| Back to top |
Posted: Sat Jan 12, 2013 4:33 pm Post subject: Re: Tool Challenge! |
Hello ASEguy,
I just looked at the picture, and it looks as if the feeler gauge is brass. I didn't notice that when I posted the picture.
It is steel, and yes you can buy a set with the sizes I mentioned.
Guido. |
| Back to top |
Posted: Sat Jan 12, 2013 4:38 pm Post subject: Re: Tool Challenge! |
Hello Iowa Barber,
The one in the picture is .003, it would be hard to use as a valve setting gauge.
Even at .015 they are pretty flimsy,
Guido. |
| Back to top |
DiyDave Tractor Guru
Posted: Sat Jan 12, 2013 4:41 pm Post subject: Re: Tool Challenge! |
I have bought sets and individual lengths of it from supply houses. We always ended up using it to shim crank bearings. |
| Back to top |
Posted: Sat Jan 12, 2013 4:50 pm Post subject: Re: Tool Challenge! |
Hello Diydave,
I have used them for that on old babbit type bearings. I have also used them for reed valves,
shimming worn housing for bearings, to name a few.
Guido. |
| Back to top |
wisbaker Tractor Expert
Posted: Sat Jan 12, 2013 5:43 pm Post subject: Re: Tool Challenge! |
I've used long ones like that to set centrifuge rotating assemblies when we couldn't send the frame with the rotating assembly for the rebuild. Didn't have to be brass. |
| Back to top |
BigMarv1085 Regular
Posted: Sat Jan 12, 2013 6:22 pm Post subject: Re: Tool Challenge! |
I have a set that I use to check the gap on a horizontal stabilizer on a Boeing 727 |
| Back to top |
