Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
450 questions
Mike Fitz
PostPosted: Sat Jan 12, 2013 11:40 am    Post subject: 450 questions Reply to specific post Reply with quote
I have a 450 gas, that has some govenor issues,it doesn't return to
idle like it should after speeding it up, I've been told it is probably
just wear, that makes sense. I am wondering how hard it is to
freshen up the govenor, or if parts are avaliable, or if there is any
one who does this kind of work. I also would like to know if the
hydraulic valve will interchange from a 350 to a 450, both were row
crop,the 450 has power steering don't know about the 350. Thanks
Mike
pete 23
PostPosted: Sat Jan 12, 2013 11:56 am    Post subject: Re: 450 questions Reply to specific post Reply with quote
Hydraulic valves are same, excluding the inner most valve on tractor with power steering and of course the flow divider valve block. Assuming factory power steering.
Far as governor, all external linkages must be in good enough condition so internal high and low stop can be reached with throttle lever. Then you would have to go for internal thrust bearing and link between gov and carb condition. Worn out weights or weak spring will cause poor response to load but not affect making it idle down slow. Loose worn throttle shaft and bushing in carb also.
Bob M
PostPosted: Sat Jan 12, 2013 12:12 pm    Post subject: Re: 450 questions Reply to specific post Reply with quote
Before you tear into the governor, first check the the linkage is properly synchronized (adjusted) to the carb throttle shaft:
Remove the cover from the governor riser (the sloped cover with a vent tube heading up to the head). Remove the cotter pin then the pivot pin from the bellcrank inside the riser. Set the governor hand lever to max speed, then pull up on both the adjusting block and the throttle shaft bellcrank as far as they will go. Now while holding the parts up, try to reinsert the pivot pin - it should slide in easily.
If it does not, loosen the locknut and turn the adjusting block up or down on the threads until the pin slides in easily. The governor will now be synchronized with the carburetor.
Bud Kaiser
PostPosted: Sat Jan 12, 2013 6:41 pm    Post subject: Re: 450 questions Reply to specific post Reply with quote
I had my govenor rebuilt 3 years ago by Motec, I think his name was Matt Gall. It works like it should.
Mike Fitz
PostPosted: Sun Jan 13, 2013 6:40 am    Post subject: Re: 450 questions Reply to specific post Reply with quote
Thanks guys, this gives me a place to start. Mike.
