| Author |
Message |
Rob Mo. Regular
Posted: Sat Jan 12, 2013 3:13 pm Post subject: Bad manifold |
Been working on a 900 Ford the past couple of days. It's coming together well, but with its lessons learned along the way. Bought a new manifold for it & installed it. The tractor wouldn't even start with it on. Odd, Right? I fixed te original manifold & put it on. The tractor fired right up. After comparing the new with the used, the casing inside the new manifold was a very course casting on the inside, I guess causing it not to flow smoothly. Amazing the there are junk new parts out there. |
| Back to top |
souNdguy Tractor Guru
Posted: Sat Jan 12, 2013 4:27 pm Post subject: Re: Bad manifold |
i doubt a simple roughness would cause issue.. but investivate deeper. I have heard of ports 100% blocked.. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50467 Location: Lake of the Ozarks area of MO
Posted: Sat Jan 12, 2013 6:25 pm Post subject: Re: Bad manifold |
I would have to agree with sound ruff should not stop it from running. I would do a rotto rooter test and make sure you can run a wire or other such thing from the carb bolt on flange to each and every one of the intake ends. I would also try a air test so as to make sure you do not have an exhaust and intake cross over |
| Back to top |
Rob Mo. Regular
Posted: Sat Jan 12, 2013 8:44 pm Post subject: Re: Bad manifold |
Wouldn't the engine be labored to create power? Or does it not create enough vacuum to affect its performance? |
| Back to top |
JMOR Tractor Guru
Posted: Sat Jan 12, 2013 9:03 pm Post subject: Re: Bad manifold |
" the casing inside the new manifold was a very course casting on the inside, I guess causing it not to flow smoothly."
I guarantee you that you have not found the source of it not running with 'rough' manifold!!!! |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1682 Location: Southeast PA
Posted: Sun Jan 13, 2013 4:15 am Post subject: Re: Bad manifold |
| JMOR wrote: | (quoted from post at 01:03:51 01/13/13) " the casing inside the new manifold was a very course casting on the inside, I guess causing it not to flow smoothly."
I agree. Jut check out all of the wonderful "turbulence/vortex" inducing snake oil people are selling on fleabay. If turbulence in the intake would keep an engine from running, then those sellers would have 100% negative feedback. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
