| Author |
Message |
55deere70 Regular
Joined: 24 Sep 2012 Posts: 253 Location: central Mass
Posted: Sat Jan 12, 2013 4:29 pm Post subject: Buda diesel injector pump timing |
I posted this on Tractor Talk, but maybe I'll have better luck over here. We have a Buda 6DT-468 on our sawmill. I have to remove the injector pump to replace a leaking freeze plug. Does anyone know how these pumps (American Bosch) are timed so I don't lose the timing when I remove the pump? I have a manual on order, but I don't know if this info is in it. |
| Back to top |
Bob Harvey Tractor Guru
Posted: Sun Jan 13, 2013 6:49 pm Post subject: Re: Buda diesel injector pump timing |
Well, if it is gear to gear, just add your own 'witness' marks where it is when you take it apart-replace as same. If otherwise (chain etc.) do the same and take some pictures and notes. HTH |
| Back to top |
OLarry from maryland New User
Posted: Wed Jan 30, 2013 2:41 pm Post subject: Re: Buda diesel injector pump timing |
I would think they are timed like the oliver engines that use the same style pumps and lavona heads.Basicly you remove the window on the side (2 small bolts)and turn the engine so all the correct marks line up then remove the pump. |
| Back to top |
Bud Tierney Regular
Posted: Thu Jan 31, 2013 10:17 am Post subject: Re: Buda diesel injector pump timing |
A little late, but if you're still looking for timing info on the Bosch I have an apparently 1950 factory manual that includes yours...
Timing (fuel) section has :
Timing Fuel Inj Pump (Bosch) Port closing---Flange Mounted---(not too long to email);
Timimg Bosch Fuel Pump---Port Opening, Base Mounted (shorter);
Timing By OverFlow Method---Port Opening Pump---(long, can try emailing pix);
Port Closing Pump--another paragraph continuation of the Overflow Method.
If your manual not factory, and you'd like this one, $5 plus media mail mailing, probably another three or so. This is printed "Bulletin # 1427A, 8x11, 68 pgs, some illus, covers 415, 468, 496 std and turbo diesels, automotive and industrial. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
