Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Rectifier Install and Generator Output
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
9n200460
PostPosted: Sun Jan 13, 2013 10:24 am    Post subject: Rectifier Install and Generator Output Reply to specific post Reply with quote
I just installed a full wave bridge rectifier on my 6 Volt Pos ground 9N. I hooked the negative terminal to the generator and one of the AC terminals to the battery as described on earlier posts (thanks!) I am getting a reasonable charge rate measured at the battery. I then checked the generator output by having the red prove on battery ground and then touching the black probe on my digital multimeter to the one wire 3 brush generator output. At idle i get 10-11 volts and up to 20 volts at higher RPMs. I was expecting something more like 7-8 volts max, although I have to admit that I didn't check it with the original cut out. Suggestions?
JMOR
PostPosted: Sun Jan 13, 2013 10:28 am    Post subject: Re: Rectifier Install and Generator Output Reply to specific post Reply with quote
9n200460 wrote:
(quoted from post at 14:24:52 01/13/13) I just installed a full wave bridge rectifier on my 6 Volt Pos ground 9N. I hooked the negative terminal to the generator and one of the AC terminals to the battery as described on earlier posts (thanks!) I am getting a reasonable charge rate measured at the battery. I then checked the generator output by having the red prove on battery ground and then touching the black probe on my digital multimeter to the one wire 3 brush generator output. At idle i get 10-11 volts and up to 20 volts at higher RPMs. I was expecting something more like 7-8 volts max, although I have to admit that I didn't check it with the original cut out. Suggestions?
Bogus reading of the digital meter in an electrically noisy environment. Analog meter needed. A better reading at battery because battery acts like a BIG filter capacitor.
9n200460
PostPosted: Sun Jan 13, 2013 10:55 am    Post subject: Re: Rectifier Install and Generator Output Reply to specific post Reply with quote
I will see if I can borrow an analog one or maybe pick one up. If I am seeing the voltage at the battery increase from 5.7 to 6.7 or so with the engine running, is it likely that there is anything wrong generator wise?
JMOR
PostPosted: Sun Jan 13, 2013 11:26 am    Post subject: Re: Rectifier Install and Generator Output Reply to specific post Reply with quote
9n200460 wrote:
(quoted from post at 14:55:25 01/13/13) I will see if I can borrow an analog one or maybe pick one up. If I am seeing the voltage at the battery increase from 5.7 to 6.7 or so with the engine running, is it likely that there is anything wrong generator wise?
Looks like generator OK & 6.7 will likely increase with longer run time. If battery begins to overcharge, remember that you have the HI/LO adjust on rear of generator to back it off.
souNdguy
PostPosted: Mon Jan 14, 2013 7:03 am    Post subject: Re: Rectifier Install and Generator Output Reply to specific post Reply with quote
slow sample rate on cheap consumer meter.
go analog like jmor said.
