| Author |
Message |
30.5s New User
Posted: Sun Jan 13, 2013 2:20 pm Post subject: 77 head |
got my 77 head up to the machine shop right now getting checked over and thinking of putting bigger valves in it. does anyone know what size valves are in an 880 and if they will fit into a 77 head? |
| Back to top |
chucksoliver77 Long Time User
Posted: Sun Jan 13, 2013 3:06 pm Post subject: Re: 77 head |
30.5, I can't tell you the size, but they are quite a bit bigger and will go right in, just grind the seats to fit and port the head. did mine 30+ years ago without changing the seats and never had a problem. good luck, Chuck PS, there are bumps in either the exhaust or intake ports,, can't remember which, just polish them, if you grind to much on them you will hit water |
| Back to top |
J. Schwiebert Guest
Posted: Sun Jan 13, 2013 3:36 pm Post subject: Re: 77 head |
One other thing you need to watch is stem height. Before I worked in the machine shop I did a couple like Chuck said and I would put Super 77 valves in them. After that I did them "right' so to say, seats on the exhaust valves correct stem height, etc. The rocker supports and push rods are longer than on a Super. You may need to do some modification to them. Is this to farm with or just play with? If you are going to farm with it what is the bore size and have you though of adding exhaust seats because of the unleaded fuel. A 550 valve would also make a good option as well. Does your machine shop have "bowl cutters" It makes for a nice job. My 2 cents worth. |
| Back to top |
dboll Guest
Posted: Sun Jan 13, 2013 3:44 pm Post subject: Re: 77 head |
for a 320 inch 77 would a 770 head be better or should I spend the money that a 770 head would cost me on flow work instead and use the 77 head? |
| Back to top |
Posted: Sun Jan 13, 2013 3:57 pm Post subject: Re: 77 head |
dboll, I think your money would be better spent on the 77 head.Chuck |
| Back to top |
30.5s New User
Posted: Sun Jan 13, 2013 7:16 pm Post subject: Re: 77 head |
the head is on a 400 plus cube motor and was planning on pulling in Div 3 so I was trying to find some air flow. I was thinking of a Murphy's intake and a little polsihing. dont know what to run for a carb, got one with the motor but dont know enough about it yet. |
| Back to top |
dboll Guest
Posted: Mon Jan 14, 2013 5:30 am Post subject: Re: 77 head |
thanks, that's what I was wondering and if I understand correctly use 550 valves? |
| Back to top |
Bryce Regular
Posted: Mon Jan 14, 2013 7:46 am Post subject: Re: 77 head |
I run a 770 head with ford 289 valves on a 421. |
| Back to top |
dboll Guest
Posted: Mon Jan 14, 2013 4:50 pm Post subject: Re: 77 head |
how close to the Oliver valves in length to the Ford valves? |
| Back to top |
30.5s New User
Posted: Mon Jan 14, 2013 7:24 pm Post subject: Re: 77 head |
from what I've read the 77,88,s77,s88,770 and 880 have the same stem dia. but i dont know the head size or valve length, the 550 thing is new to me but willing to look at. |
| Back to top |
Bryce Regular
Posted: Tue Jan 15, 2013 10:02 am Post subject: Re: 77 head |
Real close,rockers bolt right on no problems. |
| Back to top |
dboll Guest
Posted: Tue Jan 15, 2013 5:11 pm Post subject: Re: 77 head |
something to think about, pretty sure they'd be cheaper than Oliver valves |
| Back to top |
30.5s New User
Posted: Tue Jan 15, 2013 7:43 pm Post subject: Re: 77 head |
[I haven't even shopped for Oliver valves but can someone find them at an old Oliver dealer/now agco shop? |
| Back to top |
ss409 Regular
Posted: Wed Jan 16, 2013 9:41 am Post subject: Re: 77 head |
they use 318-360 mopar valves in 88 heads. dont know if they woud work in a 77? |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
