| Author |
Message |
bgud Regular
Posted: Sun Jan 13, 2013 4:43 pm Post subject: 1800a jumps out of reverse |
I've got a 1800a that jumps out of reverse when the load is taken off. I took the cover off and the reverse gear seems loose on the shaft. The book shows the gear is on a collar. Was wondering if this is common and if parts are available or if I need to find used ones. |
| Back to top |
J. Schwiebert Guest
Posted: Tue Jan 15, 2013 4:08 pm Post subject: Re: 1800a jumps out of reverse |
Just for fun, how about a serial number? Next thing, does this tractor have the pressure lube for the transmission installed? Are you talking about the reverse idler or the reverse gear on the pinion shaft? |
| Back to top |
bgud Regular
Posted: Wed Jan 16, 2013 7:43 pm Post subject: Re: 1800a jumps out of reverse |
Its the gear on the pinion shaft it moves forward and back when you put a load on and take the load off. When it moves forward it pushes the collar off and goes to neutral. The serial no. is 111369-886 and the spec no. is 18-1112.I'm not sure about the pressure lube what should I look for. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
