| Author |
Message |
mightymolinekid Regular
Posted: Mon Jan 14, 2013 12:37 pm Post subject: Machine shop (pics) |
I've mentioned it before but I thought I'd show what I have so I don't sound like I'm complaining too much lol. Can anyone see what's wrong with these pictures? The story is the same machine shop built this engine from start to finish. They had all of the parts, and I left it up to them to build it. When I dropped it off it was all pieces and when I picked it up, the only things not on was oil pan and rocker assemblies, which they did have the whole time. (I said I'd finish the assembly) The first tear down was due to a spun rear main and seized pistons, I'm tearing it down again for obvious reasons. We had no valve reliefs the first time, and saw contact so when they rebuilt it they cut the reliefs in. And they used the wrong front cam bushing so the first time I didn't have any oil to the front valves and now I realize my cam has so much clearance I lose oil pressure. 3rd times the charm he tells me......
| Back to top |
retired farmer Long Time User
Posted: Mon Jan 14, 2013 12:56 pm Post subject: Re: Machine shop (pics) |
That machine shop must have some GOOD help. Think I would be finding another shop that knows what they are doing. Hope you haven't been paying them for work like that. |
| Back to top |
Posted: Mon Jan 14, 2013 1:04 pm Post subject: Re: Machine shop (pics) |
I DID pay them (cash) the first time but they paid the labor on the #2 and now on #3 build. The frustrating part for me is I keep having to buy expensive parts and tear the tractor apart. I personally think they should be buying parts because if they did their job correctly, the parts wouldn't be ruined. I am thankful they're at least standing behind it, he says "bring it back we'll make it right". Well I wish he would have "made it right" to start with. |
| Back to top |
6pack Regular
Posted: Mon Jan 14, 2013 1:05 pm Post subject: Re: Machine shop (pics) |
What machine shop? Do not have to give names, but location to avoid!!! |
| Back to top |
d88 New User
Posted: Mon Jan 14, 2013 2:27 pm Post subject: Re: Machine shop (pics) |
what state is builder from? thats costly! |
| Back to top |
Robert Major Regular
Posted: Mon Jan 14, 2013 4:59 pm Post subject: Re: Machine shop (pics) |
Something is really wrong with that machine shop to mess up like this. I seriously think that something is maybe wrong with the cooling system and the oil flow through that block too looking at that mess and the way it's picked up on the pistons and sleeves. Maybe they have the bore and piston clearances wrong too who the heck knows now!.
I certainly would not be going back there for the 3rd time, Id be off to my legal guy! and when I won the court case and damages, go find another motor.
I'm thinking this ones done and should be buried!
Regards Robert |
| Back to top |
VicS Tractor Expert
Posted: Mon Jan 14, 2013 6:00 pm Post subject: Re: Machine shop (pics) |
I'll play devil's advocate. Did you charge the oiling system, before you started it the first time? Did you spray either in it to start it right off? Did you cold pull it, with out having the temp guage up. Did you pull it a gear to fast and lug it class after class! I paid $500 to have my blower teflon coated. Makes it .003 instead of .006 . It was cold I had put it on and was getting it ready for Tunica Sprayed either to help start it. Motor pulled down and started squeeking. Bottom line ruined $800 blower and $500 teflon job and could have twisted timing gears. All my fault! Next time I sprayed WD 40. Idled it for a while, and let break in. I was the one who wanted it tight. I had also reduced the oil flow to the blower by 1/2 . The Guy who rebuilt it thought I was putting to much oil to the bearings and pushing it by the seals. Shouldn't have paid any attention. Bottom line expect no warrenty. We are looking for 3 times the horse power these old tractors had to start with, they just have a few hours in them at this level. Check every thing your self. Ask questions and learn what the clearances should be. The first motor I had big sleeves put in, the guy put sleeves in without no lip at the top and welded them in at the bottom. Need-less to say didn't work. Found a new machine shop! Hang in there it will get better. Vic |
| Back to top |
Cody Long Time User
Posted: Mon Jan 14, 2013 6:52 pm Post subject: Re: Machine shop (pics) |
They should have felt that when they had to beat that piston in the block with a stick of wood!! It looks to me that it didn't have enough piston to cylinder wall clearance. |
| Back to top |
Posted: Tue Jan 15, 2013 4:43 am Post subject: Re: Machine shop (pics) |
I should clarify a little, there are 2 events pictured here. The scored piston and destroyed bearing is from the 1st build. No ether was used for starting, and by the time we got the fuel system primed, the guage was showing 30 psi at cranking. The failure happened on the dyno, after break in, so no I didn't get a chance to cold pull it or lug it. The shop admitted it looked to them like the bore clearance was wrong. The top pictures are after the 2nd build. Cylinder walls look OK, but I have a question for Vic (you devil LOL) what would the explanation be for cutting the valve reliefs in the wrong place on 2 pistons, and not deep enough (but in the right place) on the other 2? And for having the wrong front cam bushing installed, which makes it obvious they didn't measure that clearance upon assembly? I do agree that this is pulling, and we're trying to push this old iron way beyond what it was designed for, so the scored pistons didn't upset me all that much. Hey, stuff happens, but everything else I have wrong here is extremely frustrating. |
| Back to top |
MLPANKEY Tractor Expert
Posted: Tue Jan 15, 2013 6:40 am Post subject: Re: Machine shop (pics) |
| mightymolinekid wrote: | | (quoted from post at 05:46:53 01/15/13) I should clarify a little, there are 2 events pictured here. The scored piston and destroyed bearing is from the 1st build. No ether was used for starting, and by the time we got the fuel system primed, the guage was showing 30 psi at cranking. The failure happened on the dyno, after break in, so no I didn't get a chance to cold pull it or lug it. The shop admitted it looked to them like the bore clearance was wrong. The top pictures are after the 2nd build. Cylinder walls look OK, but I have a question for Vic (you devil LOL) what would the explanation be for cutting the valve reliefs in the wrong place on 2 pistons, and not deep enough (but in the right place) on the other 2? And for having the wrong front cam bushing installed, which makes it obvious they didn't measure that clearance upon assembly? I do agree that this is pulling, and we're trying to push this old iron way beyond what it was designed for, so the scored pistons didn't upset me all that much. Hey, stuff happens, but everything else I have wrong here is extremely frustrating. | That must be one of them quench fanatic shops . It wasnt in wisconsin was it? Allis 226 engine shouldnt have the piston at zero deck it wasnt designed that way . jmho its to tight on ring end gap for the compression and may be piston to bore also . the oil pressure loss is from main bearing clearance or cam bearings in my opinion. you should have put play dough on the piston and tighten valve lash to zero to see the piston to valve clearance by rolling it over by hand before ever starting it . the mashed thickness of playdough also gives a indication of how deep the valve relefs need cut. our shop is always open monday through friday 9 to 5 if you want to bring it down to us
| Back to top |
Posted: Tue Jan 15, 2013 2:27 pm Post subject: Re: Machine shop (pics) |
Southeast Wisconsin to be specific. Its a Moline diesel, they are designed for the pistons to come to zero deck. I have a question. I have valve contact with .012" lash now, how would putty on top of the piston tell me how deep the relief needs to be? Wouldn't it just mash it out when the valve hits? When I say contact, I mean it gets tight against the top of the piston when I roll it over by hand, I took the valve spring off and checked. I don't know much about the finer points of engine building, I had left that up to the shop, trusting their knowledge. Now I'm going to learn all I can, which I wish I'd done in the first place. Where is your shop located? How exactly do I figure out what I need for clearance? Thanks for the input and any help. |
| Back to top |
Posted: Tue Jan 15, 2013 5:57 pm Post subject: Re: Machine shop (pics) |
[quote="mightymolinekid"](quoted from post at 15:27:57 01/15/13) Southeast Wisconsin to be specific. Its a Moline diesel, they are designed for the pistons to come to zero deck. I have a question. I have valve contact with .012" lash now, how would putty on top of the piston tell me how deep the relief needs to be? Wouldn't it just mash it out when the valve hits? When I say contact, I mean it gets tight against the top of the piston when I roll it over by hand, I took the valve spring off and checked. I don't know much about the finer points of engine building, I had left that up to the shop, trusting their knowledge. Now I'm going to learn all I can, which I wish I'd done in the first place. Where is your shop located? How exactly do I figure out what I need for clearance? Thanks for the input and any help.[/quote. When it was first put together the squiahed puddy would have been the only indicator of piston to valve touching and or how much it wasnt touching |
| Back to top |
| Back to top |
Posted: Tue Jan 15, 2013 5:58 pm Post subject: Re: Machine shop (pics) |
| Back to top |
VicS Tractor Expert
Posted: Tue Jan 15, 2013 6:48 pm Post subject: Re: Machine shop (pics) |
I'd say they had a senior moment! Or talking on their cell phone while they were putting it together, or maybe even TEXING! Vic |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
