| Author |
Message |
Larry brigman New User
Posted: Mon Jan 14, 2013 12:38 pm Post subject: Oil leaking out of block at filter |
Oil leaks out of block at filter when cold.nit stops as engine warms up
The tractor is a nna 1953 |
| Back to top |
JMOR Tractor Guru
Posted: Mon Jan 14, 2013 12:58 pm Post subject: Re: Oil leaking out of block at filter |
| Larry brigman wrote: | (quoted from post at 16:38:59 01/14/13) Oil leaks out of block at filter when cold.nit stops as engine warms up
The tractor is a nna 1953 | Out of block!? Maybe block/filter interface? Gasket? Tight? |
| Back to top |
Posted: Mon Jan 14, 2013 1:39 pm Post subject: Re: Oil leaking out of block at filter |
Not at the filter it looks like it is leaking at block and piece that
filter screws to |
| Back to top |
JMOR Tractor Guru
Posted: Mon Jan 14, 2013 2:20 pm Post subject: Re: Oil leaking out of block at filter |
| Larry brigman wrote: | (quoted from post at 17:39:21 01/14/13) Not at the filter it looks like it is leaking at block and piece that
filter screws to | Sounds like yours may have been converted to spin-on filter. If yes, check spin-on adapter gasket. |
| Back to top |
Posted: Mon Jan 14, 2013 3:03 pm Post subject: Re: Oil leaking out of block at filter |
I did not know it was an adapter. Sounds like it is the problem
thanks for the help. |
| Back to top |
souNdguy Tractor Guru
Posted: Mon Jan 14, 2013 5:32 pm Post subject: Re: Oil leaking out of block at filter |
all but the later blocks had cannister/cartridge filters.. but could be converted to spin on with a new threaded arbor, adapter plate and oring... oring sounds bad.. or adapter plate is loose |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
