| Author |
Message |
tankertoy New User
Posted: Mon Jan 14, 2013 1:11 pm Post subject: 1959 case 200B with loader????? |
looking at this has new tires owner says it about 40hp? sounds like bigger than 200 rear tires are 13-6 24 which is more like 400 series gas engine exhaust is thru hood whats it worth? and how much are parts to put on a pto where it has a delete plate.owner says 3pt hitch did work but now hyd oil is milky and it doesn't lift but should be ok if oil was changed paint is good and tin is good runs great any help asap would be greatly appreciated thanks
he's asking 2800.00 |
| Back to top |
Adirondack case guy Tractor Guru
Posted: Mon Jan 14, 2013 1:34 pm Post subject: Re: 1959 case 200B with loader????? |
Got pics? details are not adding up, to make it a 200b.
Loren |
| Back to top |
casecollectorsc Long Time User
Posted: Mon Jan 14, 2013 1:46 pm Post subject: Re: 1959 case 200B with loader????? |
Plus it is overpriced. |
| Back to top |
tankertoy New User
Posted: Mon Jan 14, 2013 1:52 pm Post subject: Re: 1959 case 200B with loader????? |
it's on craigslist in high point nc it has pics but i can't seen to post pics still trying to figure out how not computer saavy ..craigslist greensboro nc |
| Back to top |
tankertoy New User
Posted: Mon Jan 14, 2013 2:08 pm Post subject: Re: 1959 case 200B with loader????? |
pic
| Back to top |
TimBinWV Long Time User
Posted: Mon Jan 14, 2013 2:47 pm Post subject: Re: 1959 case 200B with loader????? |
If you call the guy again, ask if it's got individual gauges or all in one cluster. The 200 series were seperate gauges. If it's a 210B,(with a shuttle-shift) there's no way to put a pto on it that I know of. I'd love to have whatever pieces it takes to put one on my shuttle-shift 310B |
| Back to top |
tankertoy New User
Posted: Mon Jan 14, 2013 2:52 pm Post subject: Re: 1959 case 200B with loader????? |
it has individual gauges and shuttle shift that he said works good |
| Back to top |
Posted: Mon Jan 14, 2013 3:00 pm Post subject: Re: 1959 case 200B with loader????? |
The tractor is only about 28 hp. It should have a 126 cu. in engine in it. The pto was blocked off at the factory. I heard a guy say he had a pto on the earlier, round-nose 310 with shuttle, but I can't help but wonder if he wasn't mistaken. |
| Back to top |
tankertoy New User
Posted: Mon Jan 14, 2013 3:05 pm Post subject: Re: 1959 case 200B with loader????? |
i was confused by the exhaust exiting thru the hood instead of coming out and then up like all the other pics it's a factory cut out |
| Back to top |
Posted: Mon Jan 14, 2013 3:10 pm Post subject: Re: 1959 case 200B with loader????? |
As far as worth goes, it depends on what you're going to use it for. If you want something to bush hog with, it's not worth a lot. If you want something to load dirt, then it's probably worth the price, given the new tires. ( for my area, anyways) |
| Back to top |
Posted: Mon Jan 14, 2013 3:14 pm Post subject: Re: 1959 case 200B with loader????? |
Here's some specs on it.
210B
| Back to top |
Joe (Wa) Long Time User
| Back to top |
BarryfromIA Long Time User
Joined: 26 Mar 2006 Posts: 771 Location: North West Iowa
Posted: Mon Jan 14, 2013 6:33 pm Post subject: Re: 1959 case 200B with loader????? |
This is for TimBinWV I have a 210b-h that has the shuttle and PTO. The PTO is not live or constant running, it is like what you would find on a VAC. I don't use the PTO because of the CASE suitcase weights stacked on a platform blocking it off. I have a 300b for PTO work. |
| Back to top |
Paul A Young Regular
Posted: Mon Jan 14, 2013 8:07 pm Post subject: Re: 1959 case 200B with loader????? |
It seems to be priced plenty high,especially if it has issues but a 210b is a pretty rare tractor. Loader seems to be a decent case loader too. |
| Back to top |
Stephen Newell Tractor Expert
Posted: Tue Jan 15, 2013 4:53 am Post subject: Re: 1959 case 200B with loader????? |
I'm in the Dallas area and you couldn't buy a running tractor with a loader for much less than $2800.00. I paid $2500.00 for the 210b that I bought and it wasn't in as good condition as the one you are looking at. I like the fact that it has forks with it. I had to make some for mine. I'm wondering if the one you are looking at has a bucket for the front loader?
If you plan to restore it you should re-route the exhaust outside the hood as it was originally.
This is my 210B. The after picture is a early one. I have the front loader back on now.
| Back to top |
