Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
JD60 P Steering leak
Post new topic    Yesterday's Tractors Forum Index -> John Deere
jwuertz
PostPosted: Tue Jan 15, 2013 2:30 am    Post subject: JD60 P Steering leak Reply to specific post Reply with quote
Had removed front wheels and cleaned up pedestal extension for painting. Noticed when I moved it from side to side, fluid would seep down the pedestal housing from above.
Any ideas of what the most likely cause is?
Thank you
Rich Duane
PostPosted: Tue Jan 15, 2013 4:58 am    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
Probably the lower o ring in the pedestal cylinder.
This problem requires dismantling the whole unit.
Rich
jwuertz
PostPosted: Tue Jan 15, 2013 5:31 am    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
Thank you Rich, That's what I was thinking, but was hoping not
Hugh McKinney
PostPosted: Tue Jan 15, 2013 9:09 am    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
We have a really good hydraulic shop nearby. My question to add is, where to obtain a good quality rebuild kit for the JD power steering unit? (Mine is on a 70.) Thanks.
jwuertz
PostPosted: Tue Jan 15, 2013 9:23 am    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
Probably local JD dealer. They have the orings and gaskets I need.
One more question I have before I start tearing apart, Is it possible to do this, just taking the top pedestal off, without dismantling/ dropping the rollomatic?
Mike M
PostPosted: Tue Jan 15, 2013 1:53 pm    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
All of those I have torn apart the main shaft o-rings were D shaped worn flat where the shaft turns in them.
JD sells a seal kit for those units the part number is in the 30 series parts books. I think you will need to order the seal for the actuating sleeve (part where steering shaft goes into)separatly as the 30 series uses an o-ring there too.
Dan in Ohio
PostPosted: Tue Jan 15, 2013 2:10 pm    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
Had to replace the o-rings and seals on my 70D a few years ago and here is the story of that tear down. HTH
70D power steering
jwuertz
PostPosted: Tue Jan 15, 2013 4:39 pm    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
Thank you all for the replies,
Dan, thank you for the pictures, very helpful
Jim
Hugh McKinney
PostPosted: Tue Jan 15, 2013 5:25 pm    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
That is a big, big help, so much so that I have made my decision, as soon as it warms up I am going to do this on my 70...you mentioned using a lot of hot water to install the vane seals...was that to get them soft enough to install? Thanks, Hugh
Hugh McKinney
PostPosted: Tue Jan 15, 2013 5:27 pm    Post subject: Re: JD60 P Steering leak Reply to specific post Reply with quote
Thank you very much, I was afraid that JD would no longer be handling parts for my old 70. Hugh
