Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
9n transmision drain
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
lrry
PostPosted: Tue Jan 15, 2013 1:05 pm    Post subject: 9n transmision drain Reply to specific post Reply with quote
I have a 9n i changed the main shaft seal and now i need to drain the fluid and change it the drain plug is chewed up so bad i can't get a wrench on it. there is another plug in the rear and a plug on the side of the housing that is a small plug will all of the fluid drain out through the plug on the back it would solve my problem if i could drain it through the other plugs i can get them plugs out of but the front plug is going to take some time.any info is greatly appreciated. thanks larry
old
PostPosted: Tue Jan 15, 2013 1:11 pm    Post subject: Re: 9n transmision drain Reply to specific post Reply with quote
On the 9N/2N/8N there is 3 drains one fill. Problem is you need to drain all 3 to get all the fluid out. One trick that some times works is welding a wash then a nut on to the plug so you can then get a wrench on it. Or a pipe wrench and a bottle jack and board so the wrench can not jump down and off. Also they only have the one fill place for the rear end hyds and transmission
JMOR
PostPosted: Tue Jan 15, 2013 1:13 pm    Post subject: Re: 9n transmision drain Reply to specific post Reply with quote
Looking at cut-away, you can see why all 3 have to come out for a complete drain.
Bob Harvey
PostPosted: Tue Jan 15, 2013 2:36 pm    Post subject: Re: 9n transmision drain Reply to specific post Reply with quote
If it is the large drain plug, you could try an impact gun with a sharp chisel and lower than normal air. HTH
souNdguy
PostPosted: Tue Jan 15, 2013 3:39 pm    Post subject: Re: 9n transmision drain Reply to specific post Reply with quote
2 bungs, 1 plug drain.. all ont he bottom.
try a pipe wrench held up with a jack.
if no.. then a chissle and mallet.. or even air chissle.
or weld a nut to the bung head and use a real big wrench on it.
L. B,
PostPosted: Tue Jan 15, 2013 7:04 pm    Post subject: Re: 9n transmision drain Reply to specific post Reply with quote
A small pipe wrench with a cheater, it works better then a large pipe wrench this is where big is not better large pipe wrench will want to roll off bung or plug. Welding a nut is also a good idea. The chisel and hammer will work but that would be my last resort.
heybusdriver
PostPosted: Tue Jan 15, 2013 7:43 pm    Post subject: Re: 9n transmision drain Reply to specific post Reply with quote
I had to weld a bar on mine , after it came loose , I just left an inch on bar for future use.
