| Author |
Message |
original68 New User
Posted: Tue Jan 15, 2013 2:32 pm Post subject: ensign |
ensign carb any idea on model and value. it is all brass no model # anywhere thanks |
| Back to top |
original68 New User
Posted: Tue Jan 15, 2013 2:35 pm Post subject: Re: ensign |
pics |
| Back to top |
original68 New User
Posted: Tue Jan 15, 2013 2:38 pm Post subject: Re: ensign |
tried to post pics no luck any help would be appreciated
| Back to top |
Bruce Bushnell Regular
Posted: Tue Jan 15, 2013 6:22 pm Post subject: Re: ensign |
do you know what it came off of? If it is a dual fuel I might be interested |
| Back to top |
David R Inman Regular
Posted: Tue Jan 15, 2013 7:27 pm Post subject: Re: ensign |
Well its a duel fuel. Try looking on the face that mounts against the manifold for a stamped in number. Might be near one of the studs.
I can't get agcopartsbooks.com to open right now, but I NO not think it is exactly the one used on the WD45, as it has an extra chunk of metal between the lower LP area and the T that has the throttle in the end of it and the gasoline portion on the side (IF I recall correct). Still very valuable, and much more so for what it is than for brass. |
| Back to top |
Posted: Tue Jan 15, 2013 7:38 pm Post subject: Re: ensign |
Should Read "DO not think" |
| Back to top |
original68 New User
Posted: Tue Jan 15, 2013 7:57 pm Post subject: Re: ensign |
ok i looked on the base and it is marked 1'' KGN1 any info on those #s |
| Back to top |
original68 New User
Posted: Tue Jan 15, 2013 8:55 pm Post subject: Re: ensign |
pic
| Back to top |
Posted: Tue Jan 15, 2013 9:17 pm Post subject: Re: ensign |
Hum. I looked back at the archives here on the Allis board, and found where I once quoted out of the I&T book that the ensign model was kgn1 or kg1. If you have a copy, you can look to see what they say the kgn1 and kg1 look like (I think one may be LPG only) but I don't have access to one presently.
BUT I was able to get the AC parts book to open, and you will see that there it lacks the spacer I mentioned. See link.
So at this point I'd best bow back and let someone more knowledgeable help you, as I just don't know.
I will go on to add though that I just pulled up the Nb test and it states that the carb size was 1", but I don't see where it says the ensign model.
Link
| Back to top |
Posted: Wed Jan 16, 2013 9:44 am Post subject: Re: ensign |
do you want to sell it. I really have no idea of worth, but I think it will fit my tractor
bb1950@comgen.com |
| Back to top |
stu (ON) Regular
Posted: Wed Jan 16, 2013 4:19 pm Post subject: Re: ensign |
Shop manual does say Kgn1 is combination for gasoline & LP-gas
| Back to top |
Bama Dee Regular
Posted: Wed Jan 16, 2013 7:01 pm Post subject: Re: ensign |
Never seen anything like it, I sure have more questions than answers-Hope those more knowledgable that I can enlighten us! |
| Back to top |
Posted: Thu Jan 17, 2013 6:11 pm Post subject: Re: ensign |
I think that means Kg1 is a LP only, if memory serves.
What I can't answer for original68 is:
1) if the carb he has IS the kgn1 for the WD45. For some reason I don't recall the books I've seen showing the spacer between the LP lower ave portion, and the body that mounts to the manifold.
2) what size top opining the ensign Kng1 for the 45 had. I'd guess Original68's is 1" form the 1" Kngl he gave us, but I don't know about correct for the 45. AND I thought I read here at yt that ensign had more than one size in all Kngl's. |
| Back to top |
Posted: Sat Jan 19, 2013 8:10 pm Post subject: Re: ensign |
I would like to buy it if you want to sell it
Bruce |
| Back to top |
original68 New User
Posted: Sat Jan 19, 2013 9:29 pm Post subject: Re: ensign |
bruce call me at 909 969-4985 between 900am and 600pm i am in california thanks |
| Back to top |
