MW Governor
560gaspuller
PostPosted: Tue Jan 15, 2013 6:13 pm    Post subject: MW Governor Reply to specific post Reply with quote
i just got a Supposibly m&w gov. the throttle shaft say M&W add power G-11, i popped open the cover and the numbers on the weights are, TG-5120. is this a true M&W gov.? thanks for the help.
Darin's
PostPosted: Tue Jan 15, 2013 6:23 pm    Post subject: Re: MW Governor Reply to specific post Reply with quote
If it is mw it has a bolt not a pin where it goes to carb linkage. At top
sflem849
PostPosted: Tue Jan 15, 2013 7:17 pm    Post subject: Re: MW Governor Reply to specific post Reply with quote
Darin's wrote:
(quoted from post at 19:23:03 01/15/13) If it is mw it has a bolt not a pin where it goes to carb linkage. At top
And 4 weights instead of 2.
Yeah, from your description of the tube and tag it sounds like an M&W
This is my SMTA. Sounds like yours.
This is my H.
560gaspuller
PostPosted: Tue Jan 15, 2013 7:36 pm    Post subject: Re: MW Governor Reply to specific post Reply with quote
thanks for the info, the inside of it has 2 weights,? hmm. i wonder if someone put a M&W throttle tube on a stock gov.?
D Slater
PostPosted: Tue Jan 15, 2013 8:10 pm    Post subject: Re: MW Governor Reply to specific post Reply with quote
Sounds like you have a 2 weight governor sold by M&W once. Pretty much made like a thompson governor. Picture not to clear but maybe you can see how the weight pins are retained and that they probably look like yours.
sflem849
PostPosted: Wed Jan 16, 2013 12:34 pm    Post subject: Re: MW Governor Reply to specific post Reply with quote
I always forget they made some two weight govs.
