Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Transmission Tester with Picture
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
Two Twelve Packs
PostPosted: Tue Jan 15, 2013 7:30 pm    Post subject: Transmission Tester with Picture Reply to specific post Reply with quote
How does this work?
1370rod
PostPosted: Tue Jan 15, 2013 10:10 pm    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
I seen that on ebay also, if memory is correct thats an old nick named blinky box. They are used to get the correct clutch overlap setting on RPS 34 equiped 70 series tractors, in other words powershift equiped. I have serviced these trsctors for fourty yrs and never used one. A case service rep showed us how to listen to the trans during shifting and adjust them by ear and feel. I really don;t know if other service personal actually used them much. For myself I think its a neat consersation piece, but not a required addition to the toolbox. To answer your question, you need to install those 2 censors in the test ports, hook up wires, and go through the shifts . The different colored lights told you how to adjust the then called retard screws. Rod.
Case Nutty 1660
PostPosted: Wed Jan 16, 2013 4:17 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Rod, I always wanted to have one for the shelf also as ours burnt up in our shop fire in 72, I used it on every 70 series we sold up to that point on the 200 hr "after-delivery" check-up we did, after the one burnt up and we were trying to recoup some of the losses we learded on own how to set them by ear like you said and decided we did not need one after all and like you said the "Blinky Box" was history LOL,,,,, fellow Blinky Box user LOL
mEl
PostPosted: Wed Jan 16, 2013 4:41 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Case Nutty 1660 wrote:
(quoted from post at 05:17:40 01/16/13) Rod, I always wanted to have one for the shelf also as ours burnt up in our shop fire in 72, I used it on every 70 series we sold up to that point on the 200 hr "after-delivery" check-up we did, after the one burnt up and we were trying to recoup some of the losses we learded on own how to set them by ear like you said and decided we did not need one after all and like you said the "Blinky Box" was history LOL,,,,, fellow Blinky Box user LOL
We still have ours and have used it many times. It is very sensitive to oil temp changes and if the oil is not brought to temp can cause tight overlaps that will cause the trans momentatily lock up stopping the tractor wheels sliding when the trans is backshifted by clutch pedal depresssion. I'm like the rest now, experience and your senses are your best tool.
mEl
Case Nutty 1660
PostPosted: Wed Jan 16, 2013 4:57 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
mEl I agree with you on the oil temp, we found out real early to hook them to the dyno and run them under load for 20 min or so to try for a uniform trans oil temp that seemed to get a better set on the screws/shift, always seemed like one guy would not be happy enough so we would go out when he was running in the field and do a feel test till he was happy, thats where we started to learn the box was not the best way to go, our service rep was a believer in the box and could set one with it darn good but I think he had more time using one than we could ever get with the numbers of tractors we sold, after the 200 hr service I hardly ever reset one except for a rebuild and that was 20 years later on the norm or more,,,, sorry I am ramble'in about the past way too much
1370rod
PostPosted: Wed Jan 16, 2013 6:02 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Hey Nutty, did you know fella's named Mark Henamen and Jerry Sweeney? Both were Reps when I got into this bussiness. Both hated the damn Bliney Box as they called it. They would adjust a tractor and two hrs later if the unit ether warmed up more or cooled down they found out it was out of adjustment again! Thats when they told us how to adjust without it, although they still had to demo the Box as CASE had told them. Ahhhh.... the good ole days, LOL, Rod.
Ande
PostPosted: Wed Jan 16, 2013 6:08 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Rod,I knew Mark Huemanen,he was our territory man,for a few years,and he ended up in Racine,the last I saw him.Was good to us.
Case Nutty 1660
PostPosted: Wed Jan 16, 2013 6:16 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Rod, Jerry sounds familar but can not place him, the name of the guy who was the "70" series guro that called on us I can not think of his name but I think he was involved heavy into the design of them, my fav rep was Harvey Frick, what a great wealth of Case knowlage he had, he was a good friend and could take a joke well also, sure wish I would have had a video unit back them and would have spent a couple days recording him here I go again reliving the old days cnt
1370rod
PostPosted: Wed Jan 16, 2013 10:33 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Mark was a wonderful guy, to good to be out in the country so thats why CASE moved him to Racine. When the first 2470's were gear jumpers, he tore one down for us while I just assisted to show how to repair the problem. The job sucked and he was not afraid to get dirty, always admired him for that. Rod.
1370rod
PostPosted: Wed Jan 16, 2013 10:37 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Jerry lived in E central SD, did work for JD before coming to CASE, just thought maybe he got out your way. Rod.
Agri King
PostPosted: Wed Jan 16, 2013 11:17 am    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Hey.......Do you think that would hook up to my I phone? lol. I have one of the boxes........never used it...........I should go dig it out.
TomVAC
PostPosted: Wed Jan 16, 2013 2:27 pm    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
I"ve worked at 2 different Case dealers. One they never used the blinky box, the other used it all the time. Oil temp seemed to be the key.
casecollectorsc
PostPosted: Wed Jan 16, 2013 2:46 pm    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Just curious, what was the cause of the gear jumping? Couple years ago I put a new cable on 1st and 2nd gear. Moves so easy it about falls out of 2nd and will come out under load after about 45 minutes use. Acts more like the spring on the detent is very weak, but would like to know if more serious. This on a very early 2470.
1968 403
PostPosted: Wed Jan 16, 2013 4:07 pm    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
Does anyone have a Blinky Box for sale? Or know where I can buy one?
Agri King
PostPosted: Wed Jan 16, 2013 5:18 pm    Post subject: Re: Transmission Tester with Picture Reply to specific post Reply with quote
1968 403, I have one. Send me a email. Nutty if you are interested also, email me.
Goto page 1, 2  Next
Page 1 of 2
