Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
just curious
TuckerMac
PostPosted: Wed Jan 16, 2013 4:35 am    Post subject: just curious Reply to specific post Reply with quote
I was turning the fan on my 48 H to get to the pulley lube point and I was amazed I could turn the motor without much effort. Should I borrow a compression tester? The motors I an used to need the plugs out to turn that easily. I should add that the tractor starts and runs fine.
gene bender
PostPosted: Wed Jan 16, 2013 6:08 am    Post subject: Re: just curious Reply to specific post Reply with quote
Quit worrying if it starts and runs its just fine use and enjoy.
TuckerMac
PostPosted: Wed Jan 16, 2013 6:42 am    Post subject: Re: just curious Reply to specific post Reply with quote
Thanks, I do enjoy it every Sunday for a "cigar ride". I just get curious about this old girl, I had to learn about timing, governors and carbs to get her running properly. I enjoy the mechanical aspect as much as the rides.
David R Inman
PostPosted: Wed Jan 16, 2013 6:53 am    Post subject: Re: just curious Reply to specific post Reply with quote
Some times it takes more effort than others, but I usually I take the ability to make the motor turn by rotating the fan or pulling on the fan belt as a good sign...it's not locked up.
JRSutton
PostPosted: Wed Jan 16, 2013 9:19 am    Post subject: Re: just curious Reply to specific post Reply with quote
I agree that if it runs ok don't worry about it - but if you want to satisfy your curiosity, check it out.
but I'd also check your valve lash while you're poking around in there - good idea to do it anyways.
And if you want to check your compression without borrowing a gauge, just put a little oil in the spark plug hole of each cylinder and see if it gets any harder to turn. If it does you know your cylinders are worn. (do the valve adjustment first of course)
... and knowing that your cylinders/rings are worn... all you've got to do is ignore it if it runs well enough.
and - this is probably obvious, but I've seen people forget - be damn sure the ignition is off when you're turning the engine by the fan! It could very easily start up on you.
TuckerMac
PostPosted: Wed Jan 16, 2013 9:48 am    Post subject: Re: just curious Reply to specific post Reply with quote
Thanks for the advice. I may adjust the valves just to be sure. I do not imagine it is difficult.
JRSutton
PostPosted: Wed Jan 16, 2013 10:19 am    Post subject: Re: just curious Reply to specific post Reply with quote
No it's not hard at all.
One of those things that'll take you an hour the first time as you figure it all out - and from then on you'll be an expert and it'll be a 10 minute job.
