| Author |
Message |
MI-B ill New User
Posted: Wed Jan 16, 2013 6:16 am Post subject: 8n split behind trans |
I am getting ready to switch rear differential/axles based on recommendations from this board. It appears that splitting the 8n behind the trans is a simple task once supports are worked out. Questions; what is necessary for reassembling. Prelims; pull PTO shaft? pull drop hyd. pump? pull side covers? Replace Gaskets. Any other parts likely needed? Thanks Bill in SW Mi |
| Back to top |
showcrop Tractor Guru
Posted: Wed Jan 16, 2013 6:24 am Post subject: Re: 8n split behind trans |
Be sure it is level front to back before splitting makes it push together much more easily. Drain the oil. drive wedges in between front axle and front frame so that the front doesn't flop over. |
| Back to top |
souNdguy Tractor Guru
Posted: Wed Jan 16, 2013 11:41 am Post subject: Re: 8n split behind trans |
ditto what was said.. however I see no need to drop the pump.. unless you are swapping them.. |
| Back to top |
Hobo,NC Tractor Guru
Joined: 14 Jun 2007 Posts: 10611 Location: Sanford, NC
Posted: Thu Jan 17, 2013 4:41 am Post subject: Re: 8n split behind trans |
| MI-B ill wrote: | | (quoted from post at 18:16:16 01/16/13) I am getting ready to switch rear differential/axles based on recommendations from this board. It appears that splitting the 8n behind the trans is a simple task once supports are worked out. Questions; what is necessary for reassembling. Prelims; pull PTO shaft? pull drop hyd. pump? pull side covers? Replace Gaskets. Any other parts likely needed? Thanks Bill in SW Mi |
Had to go back and find that post... Its your call but it is a EZ swap to swap the trumpets as a assembly (No messing with axles, seals and brakes).. Either will depend on were and the equipment you have on hand to make the swap...
EZ way to split
[img] [/img] |
| Back to top |
heybusdriver Long Time User
Joined: 25 Nov 2000 Posts: 817 Location: Surrey B.C. Canada
Posted: Thu Jan 17, 2013 8:06 pm Post subject: Re: 8n split behind trans |
I would be interested in seeing exactly how that
tongue dolly is mounted to the tractor. Thanks
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
| Back to top |
Posted: Fri Jan 18, 2013 4:22 pm Post subject: Re: 8n split behind trans |
Overkill as usual... Look'n at the pix I may cut the crank handle off and weld a nut on it so I can crank it with a ratchet I had to move it forward so the crank handle would clear the fender...
[/img] |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
