| Author |
Message |
ndaircapt Regular
Posted: Wed Jan 16, 2013 4:47 pm Post subject: Getting my plow going part 2 |
Hi guys,
Heres some pictures of my plow I pulled out of the snowbank today. I started the thread last week on scouring plow bottoms.
Its a John Deere 44. It says "No. 16 Frame" on the front. Its clutch lift.
What do you think of my shares and landsides? will they work? I know the hitch is set wrong, will get back to that.
Will it scour? |
| Back to top |
ndaircapt Regular
Posted: Wed Jan 16, 2013 4:53 pm Post subject: Re: Getting my plow going part 2 |
How do you tell the difference between a 44 A and 44 B?
| Back to top |
ndaircapt Regular
My questions are:
1. where can I get a reproduction or original operators manual for it besides Deere? any good websites?
2. Do you see any parts missing?
3. Do you think the shares are sufficient to plow 2-3 acres a year? If I get new shares, what am I looking for?
4. See any reason this plow wont work?
5. The tailwheel is a 4.80 - 12. Is it going to be tough to get one? Its flat. How does it come off?
6. Any way of telling what year it is? couldnt find a stamp anywhere yet |
| Back to top |
super99 Tractor Expert
Posted: Wed Jan 16, 2013 5:09 pm Post subject: Re: Getting my plow going part 2 |
The tire is the same as a small trailer tire, it will work for what you want to do.
Do you have a 4" hand grinder? I use a flap disc wheel on mine to clean the rust off,(wear a dust mask!!!) get it as shiny as you can, and then grease or paint the shares and bottoms to keep them from rusting. Soak all moving parts excessively until they free up. Chris |
| Back to top |
RayP(MI) Tractor Guru
Posted: Wed Jan 16, 2013 5:35 pm Post subject: Re: Getting my plow going part 2 |
Shares and landsides look good should last you a long time only doing a few acres. Spent a lot of time pulling one of those around the fields around here - only ours had a hydraulic lift. Properly adjusted, they were a fine plow. |
| Back to top |
BushogPapa Tractor Guru
Posted: Wed Jan 16, 2013 5:43 pm Post subject: Re: Getting my plow going part 2 |
I have GIVEN these Instructions several times and NOT ONE of you have paid any attention....
Get that 4" (or 4 1/2") Angle Grinder out (AND a good dust Mask)...
Get some of the Thin "Cut-Off wheels"..you will need about 2 for each plow bottom...
HOLD the Cut-off wheel at a low angle..about 30 degrees to the steel surface..
It WILL NOT gouge or even Scratch the steel surface, but will remove the Rust right down to the Black Oxide Under the Rust (and THAT WILL scour nicely)...
NOW, you could go back over with a "Flapper Wheel, but you really will NOT need to..
NOW..IF you Listened, you will save many hours of Work and BE Ready to Plow...
TRY IT...
"NUFF Said..
Ron.. |
| Back to top |
ndaircapt Regular
Posted: Wed Jan 16, 2013 5:44 pm Post subject: Re: Getting my plow going part 2 |
I have some PB blaster I really like I am going to take after all the fastners once I get it in the shop in case I need to take something apart. planning on "pre scouring" the moldboards too before I try it this spring. trying to prevent a repeat of the dismal try from 3 years ago, hitch miss adjusted, didnt scour, tailwheel trying to jump out of the furrow to the unplowed side..... |
| Back to top |
Posted: Wed Jan 16, 2013 5:50 pm Post subject: Re: Getting my plow going part 2 |
Sometimes it is hard to tell just how much "suck" is left in a used set of Shares..
I like to make new Landslides and leave them about 5" longer than the original on the Front and as long as is room on the rear bottom..
Helps make the slice turn over better and keeps the plow from crowding to the Left in damper ground..(keeps the furrow straighter)..
Ron.. |
| Back to top |
ndaircapt Regular
Posted: Wed Jan 16, 2013 5:51 pm Post subject: Re: Getting my plow going part 2 |
There will be a "pre-scour" cleaning done this winter using combinations of the techniques I got from this post and from the thread a week ago. Thanks Bushhog P. |
| Back to top |
ndaircapt Regular
Posted: Wed Jan 16, 2013 5:56 pm Post subject: Re: Getting my plow going part 2 |
Do you have a part # for the shares I might need? I havent looked too much "down low" to see what shape my bolts are in. Will look closer when I get it in the shop this weekend. |
| Back to top |
Posted: Wed Jan 16, 2013 6:19 pm Post subject: Re: Getting my plow going part 2 |
No numbers, here..but your shares appear OK..but a picture can be deceiving..some shares were designed to have a greater amount of Suck than others...
I have seen a JD 2 Bottom plow go from "going in good", to "won't go in at all" in just a couple of rounds..
Could be the conditions were getting Dryer maybe it was the shares.
Some just change over to "High Speed Bottoms", so they can use "Throw-Away" shares..that are much cheaper and easier to find..
Ron.. |
| Back to top |
ndaircapt Regular
Posted: Wed Jan 16, 2013 6:29 pm Post subject: Re: Getting my plow going part 2 |
Good to know.... I read somewhere that high speed bottoms takes a whole different frog? |
| Back to top |
Brian Dan Regular
Posted: Wed Jan 16, 2013 6:32 pm Post subject: Re: Getting my plow going part 2 |
Wate till spring and find an old gravel pit.
plow a couple hundred feet and your plow will be clean. My dad did that all the time back in the day. |
| Back to top |
ndaircapt Regular
Posted: Wed Jan 16, 2013 6:33 pm Post subject: Re: Getting my plow going part 2 |
Thats what appears to be on it right now is a "trailer tire" 4.80 - 12 an Armstrong? Is that tubeless? Does those four bolts just come out and to get off the hub? |
| Back to top |
Greg K Long Time User
Posted: Wed Jan 16, 2013 6:34 pm Post subject: Re: Getting my plow going part 2 |
Where do you find the tires for that plow? |
| Back to top |
