| Author |
Message |
matt p Regular
Posted: Wed Jan 16, 2013 7:41 pm Post subject: Bloodhound Sniffs Out Carb Problem |
This is my pilot when adjusting carb got the carb apart cleaned it really well then soaked it overnight. tonight went out to the shop and could'nt bellieve how dirty fluid was, I used new clean fluid for the overnight soak,it looked like coffee . Glad that guy's insist on the long soak. The last kit was put in a little too quick the only gasket was the middle one. The throttle butterfly was worn almost twice the size trottle rod, I think this might have added to my idle woes. Do you think that with my bad distrubuter and weak carb would that be why the crankshaft broke????
| Back to top |
samn40 Tractor Expert
Posted: Thu Jan 17, 2013 5:56 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
The most common reason for broken crankshafts is too slow a
tickover, especially so on diesels. The Masseys are factory set to
idle at around 750 revs but a lot of users turn them down to about
550 RPM.
Sam |
| Back to top |
Tony in Mass. Tractor Guru
Posted: Thu Jan 17, 2013 7:23 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
So? Is Fred Bassette going to rebuild the carb? That's a hard job for someone who doesn't have fingers. I don't remember you having a broken crankshaft? Or is this a 'dog tale'? |
| Back to top |
Dieseltech Long Time User
Posted: Thu Jan 17, 2013 7:53 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
At least he won't have any exhaust in his face, like that big rig look! |
| Back to top |
trac Long Time User
Posted: Thu Jan 17, 2013 7:59 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
Sam what do you mean a (tickover)slow turning when starting motor? I thought the timing was off the injectors and such. |
| Back to top |
Inno Tractor Expert
Joined: 11 Nov 2009 Posts: 1868 Location: NW Ontario Canada, Near Beautiful Rainy Lake
Posted: Thu Jan 17, 2013 8:03 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
I'm assuming he means idle speed. Never heard of that causing problems before, might have to turn up the idle on mine. |
| Back to top |
Posted: Thu Jan 17, 2013 8:12 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
When I worked at MF dealer years ago we set low idle on Continental gas engines at 500 RPM, and Perkins diesels at 750-800 RPM. |
| Back to top |
matt p Regular
Posted: Thu Jan 17, 2013 8:27 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
Hey TONY thats what started my trip into tractor restoration.Used the tractor for the summer then the first snow fall I use it to clear the driveway .I heard a really rattle coming from top engine so I shut it down.I called a friend he said it maybe just carbon build-up on top of pistons so I pulled the head and the pistons were pretty clean,the only thing I could see is #2 piston was a little shiny like cresent moon where it had hit the head. Next the oil pan I did'nt see anything until I rotaded the crank, it was a tiny little crack as I moved it further I could see it was broken.I called a couple of places and they wanted $2800 to $4600 plus the cost of crank to rebuild,if they could find a crank. Well needing the tractor I learned how to use the internet and ordered the rebuild kit with crank fromYT. When I ran into some problems?questions the guys at YT told me about the massey forums, wish I new about them sooner might have saved a lot of mistakes!!! Oh well live to learn |
| Back to top |
Posted: Thu Jan 17, 2013 10:22 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
So Matt! Did you get parts thru YT here? Do they ship to Canada now? Or is Alberta now part of the states?? ... yikes, that's not good either...
My crank was slightly bent, so another 50 bucks when turned down... but that was because of the inserts riding on top of each other.
$4,600? Four thousand... six hundred ....dollars????? !!!!!! Yep, you're still in Canada alright...
but then again, $1000 to 1500 in parts, 100 an hour in a classy shop... taking a man most part of a week... I suppose... |
| Back to top |
matt p Regular
Posted: Thu Jan 17, 2013 11:45 am Post subject: Re: Bloodhound Sniffs Out Carb Problem |
Tony I got the parts from YT then had them sent to a broker in sweetgrass Montanna.Its about 3hr round trip from my place.Just bought tune-up parts points,cond,plugs,cap and rotor for $83. I see on the site for $24 or so.Carb kit was $44 and no new throttle shaft. Napa says they can't get the right kit. Inno suggested sparex in edmonton I'll give them a call. BTW |
| Back to top |
Inno Tractor Expert
Posted: Thu Jan 17, 2013 1:32 pm Post subject: Re: Bloodhound Sniffs Out Carb Problem |
Yeah, machine shop rates here are crazy!! Had a couple pins machined for my loader........he matched them perfectly and did a great job.......way better than was required. I was looking at around $500 or so if I recall correctly. Next time I'll just get the correct size stock and drill holes for pins and call it a day!
How much was it for brokerage fees to order parts that way? |
| Back to top |
Posted: Thu Jan 17, 2013 2:39 pm Post subject: Re: Bloodhound Sniffs Out Carb Problem |
I want to open a repair shop and motel in Sweetgrass, and another in Milk River.... immagine breaking down there? Or getting stranded at the border for paperwork? What a lonesome place to be in a pickle... |
| Back to top |
matt p Regular
Posted: Thu Jan 17, 2013 3:08 pm Post subject: Re: Bloodhound Sniffs Out Carb Problem |
Inno the fees were $5 under 50lb and $10 ,50lb to100lb all I had to pay is Gst because I was not in the U.S for 48 hours. I do not have good parts diagram for my 202 throttle under the dash where the cork washer would go,think I'm missing some pieces. Any chance you would have one?? |
| Back to top |
matt p Regular
Posted: Thu Jan 17, 2013 3:21 pm Post subject: Re: Bloodhound Sniffs Out Carb Problem |
Tony have you been to sweetgrass? I think it is really loanly place maybe all boarder crossings are like that!. That price for rebuild of $4600 did'nt include the cost of crankshaft, had one place quote me $1085 plus shipping |
| Back to top |
Inno Tractor Expert
Posted: Thu Jan 17, 2013 5:55 pm Post subject: Re: Bloodhound Sniffs Out Carb Problem |
Probably the best source for diagrams is acgopartsbooks.com
From there you click on "view books" to the right of Guest User. Then select Massey Ferguson from the pull down menu and type in your model. It will come up with the 202/203/204/205 listing on top. Click that and you have access to the entire parts list for your tractor complete with zoomable exploded views and part numbers for all the parts and most times you can make out in which order to re-assemble them. If you haven't already been there it's another one of those "why didn't I have this sooner" things.
Just had a look for the diagram and noticed something funny. The diagram which has the foot pedal does not seem to have a compensating spring at all.........strange! That may explain why my 202 didn't have one and didn't seem to need it, the governor worked fine without one. |
| Back to top |
