| Author |
Message |
4440 puller Guest
Posted: Thu Jan 17, 2013 8:51 am Post subject: 400 super diesel |
How can I tell if a 400 is a true super diesel? I have a neighbor who is the original owner of one and he said it was a super diesel but another guy said it wasn't. Im going to try to get it bought either way as it has the wide front with it, a set of mounted plows and set of semi mounted plows. They had a 425 picker on it but they scrapped it last fall before i knew it. |
| Back to top |
Case Nutty 1660 Tractor Guru
Posted: Thu Jan 17, 2013 8:52 am Post subject: Re: 400 super diesel |
one easy way is the pto lever with have a lock for the brake, regualar 400's did not have a pto brake |
| Back to top |
Don Rudolph Long Time User
Posted: Thu Jan 17, 2013 10:07 am Post subject: Re: 400 super diesel |
There are a couple of things different on a Super. As Tom said a Super will have a PTO brake and also on the steering column there is a "boss" for the eventual Case-O-Matic lever on the 800. It is on the left side of the casting and is a flat spot that would be drilled and threaded if the column was used for COM. On the Super it is not drilled or threaded, but you can see how it would work. Also the block for a Super should be A1111, the same as a 700 or 800. I also believe the pump is set at 100 RPM higher than a regular 400. I need the experts to wheigh in on that. In addition the tool box is much bigger and does NOT have CASE stamped into the cover. That should give you enough clues to go by. I hope you have found one! Don |
| Back to top |
1031D Tractor Expert
Joined: 31 Jul 2004 Posts: 1700 Location: Southern Wisconsin
Posted: Thu Jan 17, 2013 10:18 am Post subject: Re: 400 super diesel |
| Don Rudolph wrote: | | (quoted from post at 11:07:24 01/17/13) There are a couple of things different on a Super. As Tom said a Super will have a PTO brake and also on the steering column there is a "boss" for the eventual Case-O-Matic lever on the 800. It is on the left side of the casting and is a flat spot that would be drilled and threaded if the column was used for COM. On the Super it is not drilled or threaded, but you can see how it would work. Also the block for a Super should be A1111, the same as a 700 or 800. I also believe the pump is set at 100 RPM higher than a regular 400. I need the experts to wheigh in on that. In addition the tool box is much bigger and does NOT have CASE stamped into the cover. That should give you enough clues to go by. I hope you have found one! Don |
Also, the sides of the grill are cut out for the cultivator stay rod mounts to bolt on. |
| Back to top |
Agri King Long Time User
Posted: Thu Jan 17, 2013 11:23 am Post subject: Re: 400 super diesel |
To bad about the picker. That would have been great to leave it all together. |
| Back to top |
Jim from Cal Regular
Posted: Thu Jan 17, 2013 5:32 pm Post subject: Re: 400 super diesel |
An addition to the parameters below:
The Super is configured with:
a. A American Bosch injection pump with RPMs - 400 to 1550, a regular 400 is 1450
b. The side forward sheet metal has opening (one on each side [a hole about 1” by 2”]) where implements can be bolted to the two ¾ inch bolt holes. These are on only late 1957 built 400’s and on all supers
c. Super 400 also had pressurized cooling system
D. Super serial number start with 8106131 |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
